How to Change leds in a rca LED55C55R120Q
  • Tech 57
    • Aug 2014
    • 37
    Hello i am working on a rca Model Led55C55R120q
    Has anyone ever changed leds in this model.
    I need disassembly instructions don't want to crack the screen.
    i know the rca 65inch you pull the back right off panel face down this one not sure.most panels i worked on the bezel comes off the front.
    Thank you
  • freakaftr8
    • Oct 2012
    • 3743
    Re: How to Change leds in a rca LED55C55R120Q
    This models tricky is a lot of stuff attached to the speaker cover assemblies. The plastic that surrounds the speaker assy pops off the back and alot of mounting hardware theree if I remember the LCD panel if standing upright could fall forward. This is a prime example of cheaply made displays.
    There is no metal framing on this TV. The plastic bezel holds the LCD panel and the diffusers in place.
    Love your avatar by the way I still work on tube type equipment and old console TV's. Restored an RCA CTC-10 not.too long ago.
    • Tech 57
      • Aug 2014
      • 37
      Thank you
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Love your avatar by the way I still work on tube type equipment and old console TV's. Restored an RCA CTC-10 not.too long ago.[/QUOTE]
        Really like it, too.
        • Tech 57
          • Aug 2014
          • 37
          guess no one has the answer
          i figured it out myself
          • freakaftr8
            • Oct 2012
            • 3743
            That good. Sorry couldn't be more help. The one I performed LED strips on was a 65 inch RCA LED65G55R120Q last year. It was half disassembled when I got it for repair. I sent it back to him the same way
            • Verlengsnoer
              Bios splash/logo change
              by Verlengsnoer
              at firs, i hope this is the right place to post my question.
              Im looking for a tool to change the bios logo.
              everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
              i know that HP has a build in option to change the splash logo.
              but i want to change the manufacturer logo to an own logo.
              I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
              10-28-2022, 09:52 AM
            • Pipolups
              Corsair K70 LUX RGB dying LEDs
              by Pipolups
              Hi there !
              I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
              Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
              10-08-2024, 11:58 AM
            • pni
              Backlight panel diffuser melt by backlight leds broken
              by pni
              Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
              10-12-2025, 12:08 AM
            • notallbad
              TCL 55RP620K power board issue
              by notallbad
              Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
              0% p_dim at 1.65v and a_dim at 1v
              50% p_dim at 3.3v and a_dim at 1.65v
              100% p_dim at 3.3v and a_dim at 2.88v
              Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
              Leds are 2 rows of 15 6v leds.
              On inspection of the power board found diode MBR3200 shorted so replaced with...
              07-12-2025, 05:45 AM
            • rustinjust
              Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
              by rustinjust
              My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
              The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
              It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
              I have to turn the tv off and then on again with...
              09-28-2023, 12:23 PM
