I have an LG 50PS60 that has Sound but no picture Ysus board EBR6183001 EAX60982501, I am 99% sure it is the Ysus board because I swapped a board from my other identical TV and it worked. I would like to take a shot on fixing the board, anyone know what component / components may have failed. I have checked all my voltages from the main board and all are very close to spec and I have checked all the fuses on the Ysus board and all are good. Also I know bad buffer boards can kill the Ysus board, if there bad/shorted buffer will this kill the Ysus board instantly or after the TV has been on for a while. Thx
LG 50PS60 Sound but no picture Ysus board EBR6183001
Tags: None
Re: LG 50PS60 Sound but no picture Ysus board EBR6183001
Attached is a picture of the screen, the Ysus board & the voltage ratings. I am 95% sure the Zsus board is good because it works perfect in another TV.
Ysus Voltages
V 195.1
VA 59.94
5v 5.06
Zsus Voltages
195.1
5v 5.06
15v 18.01Attached Filesif you find these attachements useful please consider making a small donation to the site
I have ohmed out the YSus buffers and they appear to be good. I have two questions keeping in mind I have two exact same TV's so testing is very easy.
1) If I put what I think is a bad Ysus board in the good TV just to verify if it is bad will it damage or short any other board or component in the TV ?
2) For the slight chance the Y buffers are bad and I put a good operating Ysus board in to test the TV, would it kill the Ysus board instantly or after a few min running ?
ThxComment
Update, Y buffers are good, ohmed them out to floating ground. Installed working Ysus board from my other TV and now its working so the problem is 100% a bad Ysus board. When the bad board is in the TV when I turn it on sometimes it will give a blue & red pixel screen and sometimes it will be very dark with blotches of color. Input voltages are good from the power supply, all fuses are good and solders visually look good. Any thoughts on what to look for or what might be bad on the board would be appreciated. I did notice the coil by the fuse is lose but i ohmed it out and it appears to be fine. ThxAttached Filesif you find these attachements useful please consider making a small donation to the site
Hey goldbird78, mmartell asked for you to list your -Vy and Vscan voltages. It's kind of late, so I may have missed where you listed them. Those two are adjusted on the Y-sus, so that's probably a good place to start. Looks like your set is looking for a -Vy of -180, and a Vscan of 150. The attached diagram may help.Attached Filesif you find these attachements useful please consider making a small donation to the site
I could not find those test points before, I will check them out and report back. Thanks.Hey goldbird78, mmartell asked for you to list your -Vy and Vscan voltages. It's kind of late, so I may have missed where you listed them. Those two are adjusted on the Y-sus, so that's probably a good place to start. Looks like your set is looking for a -Vy of -180, and a Vscan of 150. The attached diagram may help.Comment
The -VY on my board was is a different location.Hey goldbird78, mmartell asked for you to list your -Vy and Vscan voltages. It's kind of late, so I may have missed where you listed them. Those two are adjusted on the Y-sus, so that's probably a good place to start. Looks like your set is looking for a -Vy of -180, and a Vscan of 150. The attached diagram may help.
Readings
VSC 150.4
-VY 180Attached Filesif you find these attachements useful please consider making a small donation to the site
Try adjusting the SET UP and SET DOWN pots on the board (maybe RAMP UP / RAMP DOWN) and see if that has any effect.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
The SET UP made no change, the SET DOWN did make a change to the color but to the static/snow in getting on the screen.
Is the picture also jumping up/down? Could you show us a video of the issue?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yes the picture jumps around a little and is unstable, hard to see on the video's. Also the picture goes lighter and darker. See youtube links below
https://www.youtube.com/watch?v=RpRADd-jPHY
https://www.youtube.com/watch?v=n_hOS5x4yeUComment
Give the chips highlighted a blast of freezer spray and see if anything happens.
You can use a can of air if inverted to produce freezer spray. Compressed butane also works, please beware of the flammability hazard around high voltage though.
For the chips at the top you can directly use freezer spray on them while the set is on, careful to make sure the liquid does not drip down the board. You may want to lay the TV down for this, but in such a way that you can observe the screen. (Or apply what I wrote below for top ICs too.)
For the ones on the bottom, either make sure the board is OFF and allow the condensation to fully evaporate (except around the top of the chip) OR you can damp a piece of cotton wool and dab it on top of the IC to cool it down. Be careful of the high voltage in this part of the circuit.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi Tom, thanks for the help. I got them nice and frosty white waited 30 second for any residue to evaporate but unfortunately no luck.
For the ones on the bottom, either make sure the board is OFF and allow the condensation to fully evaporate (except around the top of the chip) OR you can damp a piece of cotton wool and dab it on top of the IC to cool it down. Be careful of the high voltage in this part of the circuit.Comment
Btw, I do have a donor board, so if there is anything you feel that may need replaced I can give it a shot.Comment
I think a likely problem is those ICs but I can't be sure.
It's difficult to trace this problem without an oscilloscope, do you have one?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I repaired a 50PS30 recently. It too had good voltages but an odd pic and the set_up pot had no effect on the picture at all but the other pots did. It was the large 2.2ohm resistor feeding the pot, in your case R363. May as well measure it.Comment
No oscilloscope yet, that is on my "to get list" Are there reasonably priced one's for a hobbyist ?
Thanks, I sure will and report back.
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... - Loading...
