Will a AB SN module replace a AD module?
Panasonic TC-p42s30 TNPA5349AD or AB
Tags: None
Re: Panasonic TC-p42s30 TNPA5349AD or AB
SN will replace AD but the AB wont replace the SN but you can AD to AB if you've got the time though personally Id SN or SC or even SD but tbh AB SN can replace a whole AD module though Id stick to stock parts and not play.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
by questoreHello Everyone,
I need your help, maybe you have know where to buy a replacement.
I have a NM-D562 laptop motherboard that has a burned 0.75_ALW converter. (the layers and the pins also burned so i dont want to restore it but i need a replacement)
I have checked with lab power supply output (0.77V) laptop works, so i need a DC-DC module that can do its job.
According to schematic datasheet what i need on 0.75V_ALW:
Vout=0.75V±37.5mV
Vset=0.752V±1.46%
Vref=0.6V
TDC=4A
OCP=9.5A TYP=10.5A MAX
OVP=(1.15~1.25)*Vout
UVP=(0.6~0.7)*Vout...-
Channel: Common Parts Library - Datasheets
by BigPeteI picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
Unfortunately the whole machine has to come apart to fix it.
I have... -
...1 Photo11-20-2024, 08:52 PM -
by repair-itI replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently... -
by m1ch43lzmHi everyone
I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector... - Loading...
