Vertical light banding on edges of Panasonic 50CX802
  • jonnyapps
    • Jul 2017
    • 35
    Had some great help on here with a previous TV so I'm back!
    Recently picked up a 50 inch Panasonic CX802 and it has bright vertical bars on both edges, which I have pictured
    The image is an exaggerated version of the effect (finding the worst shade in Photoshop and over exposing the photo). It is only the far right/left brightest strips that are the problem when watching.
    Frustratingly it also has an effect on colour saturation in those areas and is visible when watching films etc.
    I have tried many combinations in the picture settings of the TV to no avail. None of the preset modes do away with the issue, nor does following AVForum's recommended settings.
    I suspect there's not a lot I can do about it but I'm not afraid to get my hands dirty if there are any options so please let me know if you have any suggestions.
    Thanks for your time.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Vertical light banding on edges of Panasonic 50CX802
    Need to see a picture with content on its screen to further diagnose. From here it looks rather normal if you superimposed the picture. Could be LED backlight bleed If it is edge lit
    • jonnyapps
      • Jul 2017
      • 35
      Sure, I'll take some photos/footage tonight when home.
      I find it odd because most other complaints about the TV are the opposite. This for example.
      • jonnyapps
        • Jul 2017
        • 35
        The following are all 'correctly' exposed and match my viewing experience.
        Here is a photo on a menu:
        Here is a video with prevalent greys: https://i.imgur.com/HhjykbO.mp4
        and here is the issue in action, with paler sides:
        I have video footage of the scenes those are grabbed from too but it's stubbornly refusing to upload currently.
          It's probably backlight non-uniformity and unfortunately, there's probably very little you can do.
          • freakaftr8
            • Oct 2012
            • 3743
            Wow that's quite a bit of backlight bleed! Does this change with a gentle twisting motion back and forth? That's crazy for a high end tv!
            • budwich
              • Jul 2015
              • 3097
              what are the chances that someone else was in the set and changed out some of the leds.
              • jonnyapps
                • Jul 2017
                • 35
                Plausible in so much as I bought it secondhand. Thankfully I only paid £350 for it. Not afraid to open it up and find out, if it would help anything.
                • jonnyapps
                  • Jul 2017
                  • 35
                  Nope. No change. I've also tried loosening/tightening the screws in case it was a pressure thing.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    I would say the diffusers are no good. Possibly partially melted from heat from the led's. This is considering that others seem to have darker bars on each sides. Design IMHO
                    • jonnyapps
                      • Jul 2017
                      • 35
                      Unfixable?
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Worth stripping the TV to have a look. I've just repaired edge LEDs on two 50" Panasonics.
                        The first one went smooth, the second and I mustn't have put it back properly as there is light leakage on the right hand side where my LEDs are. Either the thick plastic that transmits the light is out of place or the LED strips aren't sitting flat.
                        • jonnyapps
                          • Jul 2017
                          • 35
                          Can't say I've ever tried such a thing before. I'll have a look around for some tutorials and calculate the odds of catastrophic failure!
                          • kca
                            • Feb 2016
                            • 548
                            Did you ever have any luck with this, jonnyapps?
                            • jonnyapps
                              • Jul 2017
                              • 35
                              Sorry for the delayed reply.
                              I didn't take it any further and have been tolerating it for now.
                              • Alicat
                                Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                by Alicat
                                Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                Model number is TH-50PZ85U
                                Power comes on and the red power light stays on solid.
                                Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                I also hear a few clicks.
                                I also think my parents said there was a thunderstorm and the TV failed after that.
                                Section 6 in the service manual talks about power and no screen,...
                                10-30-2024, 10:09 AM
                                Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                I also have back when Light of America had these light bulbs available for yard lights
                                The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                While the Lithonia lighting fixture has all most certain bulb failure
                                So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                I have only had this light fixture for not more than a year if it...
                                07-02-2023, 03:45 PM
                              • ItepK
                                Panasonic TX-P42G30E green light blinking, no video, no audio
                                by ItepK
                                Hey everyone!
                                I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                                This post describes my entire troubleshooting process of this TV.
                                When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                                I've taken the unit apart, and I've started to check some voltages:
                                • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                                12-22-2023, 05:06 AM
                                LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-07-2024, 03:40 AM
                                LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 09:10 PM
