Sumsung Plasma Tv PN50A550 dead
  • ivtec
    • Dec 2008
    • 1967
    Hguys;i have here a Samsung Plasma Tv PN50A550 Power supply that has a blown main fuse and a huge black spot around the 2 moves resistors ,here some pics,before anything of do you guys think of it,this tv belongs to my friend and i advised him to bring the power supply only because tv is so heavy and since it was completely dead,i assumed it was the power supply issue,any thoughts thanks?
  • Dumah Brazorf
    • Jun 2013
    • 179
    • Italy
    Re: Sumsung Plasma Tv PN50A550 dead
    It's dust or sawdust?
    Traces seems big in that area so I think you can repair the damaged ones easily.
    Those resistor are inrush limiting current ones so probably there's a short after them. Check the main bridge rectifier.
    • ivtec
      • Dec 2008
      • 1967
      Thanks Dumah; the 2 bridge rectifiers seem to be ok at least when checked with the diode function,the 2 diodes next to the limiting resistor are ok too,one of the limiting resistors is cracked in pieces the other seems to be intact,when i repair the traces and replace the limiting resistors and the fuse can i connect the power supply to power without being connected to the tv?thanks
      • Dumah Brazorf
        • Jun 2013
        • 179
        • Italy
        Check for short after the bridge rectifier, expecially mosfets.
        • ivtec
          • Dec 2008
          • 1967
          Thanks Dumah; i checked all these components on the heat sink 20N60C3 and the diode and all show short in circuit,tomorrow i will take them out and see if they are ok, but i think these are short.
          do you know if this sumsung kit has those components included ? 20N60C3
          http://www.shopjimmy.com/samsung-bn4...repair-kit.htm
          • R_J
            • 9549
            Its a very good chance that the contacts are bad in RLYE801 relay. The relay should short out the thermistors when the tv is running, if the contacts are bad all the current is drawn through the thermistors and they burn up.
            If you don't find any shorted parts elseware, replace the mov's and the relay and it should work
            I think they are SCK-801's
            With the thermistors open you won't get any standby voltage if I remember
            Also check FB801 fuse, if its good I suspect the standby circuit is o.k.
            • ivtec
              • Dec 2008
              • 1967
              So far components checked bad out of circuit are, 2 mosfets 20N60C3 and Fuse FB801,
              2 Sck 0512 inrush resistors, also i checked ordering these parts from different sources will cost about 40 bucks including shipment and not sure thing cause it maybe something else bad, i checked this power supply the cheapest i could find about 45 bucks,don't know ! what do you think?
              http://www.buyqual.com/samsung-bn44-...8aAsolEALw_wcB
              • R_J
                • 9549
                If it is "FB 801" that is open, then UB801 standby ic likely bad, shorted. FE 801 is the main fuse off the a/c line. I don't where the 2 mosfets you mentioned are on the board, I don't have this schematic, I'm going by SJ pictures of the board. $45.00 is not a bad price, if you add up the parts you need to repair this one it mmight be cheaper to just replace it.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Main fets short on these vtec kicked in yet
                  • ivtec
                    • Dec 2008
                    • 1967
                    Well thanks guys,talked to this tv owner and he doesn't want to spend that kind of money on this plasma,i guess he's going to send it to the dumpster,i don't blame him,i wouldn't ,thanks to you all for trying to help., appreciate it.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Even if you did get it repaired it is an A series so be looking for vertical lines or horizontal lines in the screen as it starts to burn away
                      • badcappo
                        Dead Panasonic Viera TX-P65STW50 Plasma TV
                        by badcappo
                        Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                        Diode type G972s6 - D101 with a short
                        Mosfet 06N90E - Q301 shorted
                        Fuse T5AH 250V - F103 blown
                        Diode D301 shorted
                        Relay DG1U-17VDC II - RL001 blown
                        I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                        11-24-2024, 11:27 AM
                      • Super360
                        Samsung PLASMA PN50B530S2F DEAD
                        by Super360
                        Hi everyone I have this plasma here that has no standby light and is completely dead. I opened it up to see extremely dirty and dusty to which I cleaned but made no difference. So I checked all fuses good. I checked the standby voltage 5 volts good. Then I did that plasma control board test by shorting the pins(THANKS 2 TVTIMMY) and the tv actually turned on and made a sound. Does this mean I need a new motherboard?...
                        12-16-2021, 09:25 PM
                      • double_DD
                        How can I be sure that my EC chip is dead?
                        by double_DD
                        As the title suggests, how can I be sure that my EC chip is really dead?
                        I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                        Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                        03-12-2025, 07:47 AM
                      • KYBOSH
                        Samsung PN59D8000 Plasma - Dead Screen
                        by KYBOSH
                        Got my hands on another non-working TV this weekend.
                        Person I got it from says he heard a load POP and the picture died.
                        Nothing to see when I opened up the back.
                        I found a single thread about this model on this forum and in it @dick_barton provided a very useful Fast Track Troubleshooting guide.
                        I followed the steps and found that my power supply was good (good Va & Vs) but only after unplugging the X & Y Boards.
                        I narrowed the problem to the Y-Sus board and found shorted IGBT (RJP30E3). There were also two other casualties...
                        01-01-2023, 01:20 AM
                      • Super360
                        PN43D450A2DXZA Samsung Plasma DEAD
                        by Super360
                        Hi ya'll I got a tv that is completely dead here. I opened the back to see bulging caps on the psu. Anybody have any good prices for some high quality low esr caps for this sucker?...
                        12-10-2021, 05:28 PM
