Sony KDL 46XBR2 No Video but sound
  • mike123333
    • Oct 2011
    • 196
    I have a Sony KDL 46 XBR2 tv that stopped working, it has sound but no video. I have tested the voltages and everything seems to be fine off the PSU. there is an issue with my BES board and not constantly getting a 5 volt line, the voltage goes to 5.2 then drops to 0 then back up to 5.2V. this line feeds the TCON board. I have the TCON disconnected and still the same thing. I did manage to get the SM from here in another thread about the same TV and issue which did not conclude anything. looking at the schematics and the components what is in question is the switching regulator and Mosfet, the diode test fine, the capacitor test fine both in ESR and Capacitance. I would appreciate any help in identifying which is the culprit so can get the 5V back on steady so I can continue the troubleshooting. Would it make sense for me to inject a 5volts to that lien to test if that is the main issue?
    The diode, inductor and capacitor for the 5 volt line are on the opposite side of the board.
    There is no backlight , I did inject 5volt on the backlight signal and that brought the backlight on but was dim, so there is nothing wrong with backlight circuitry.
  • mike123333
    • Oct 2011
    • 196
    Re: Sony KDL 46XBR2 No Video but sound
    Can I assume that since the voltage is going from 0 to 5.2v that the mosfet is working and I have issues with the ic switching regulator. Unless the mosfet is not switching quickly . I see the voltage rise and drop is about a second apart.
    • mike123333
      • Oct 2011
      • 196
      I found what the issue was, I disconnected the TCON and the fuse was blown, took a 0.0005" wire and jumped the fuse and everything seems to come on, I have not hooked any videos to it yet, I want to replace the fuse what size fuse do I need, 2A or 3A? the TCON works off of 5V not 12V source. it seemed that the TCON gives feedback to the switching regulator.
      • R_J
        • 9535
        Replace it with the same value that was there before, there should be a letter on the fuse indicating the value. since you didn't post the t-con number I looked at shopjimmy. If it is a (T) thats 5 amp
        • mike123333
          • Oct 2011
          • 196
          Thanks for the quick response it is a T.
          • EagleVideoGuy
            Van
            • Mar 2018
            • 3
            Hi mike123333,
            I have the same issue with my KDL-46XBR2 TV. I joined today, posted my information on the "greeting page", logged out and back in but can't seem to edit my profile. I've been trying to obtain the "Sony KDL-46XBR2 Training Manual FIX Direct-View LCD Television Chassis" at manual-archives.com, but MalwareBytes kicks in and not sure which links to take. I was trying to remove the heat sink and stopped, didn't want to force the issue. I was told to check the fuse, trying to find directions. Any thoughts?
            My wife is in a rehab center. Fell backwards off the front porch 2nd step, fractured her pelvis and broke her wrist, so I'm kind of out mostly. Might need a new thread? Regards, Van
            • EagleVideoGuy
              Van
              • Mar 2018
              • 3
              I did have the manual already. The only indication of the T-CON board I can find is a photo called "Under Heat Sink", and all it has is a photo of the heat sink. Nothing I see shows removing the heat sink and the T-CON board. A T-CON board is not mentioned anywhere. I'm confused on that point.
                • 12194
                • U.S.
                https://www.youtube.com/watch?v=yTnkOfwBGGE Tcon testing, any fuse on the board will start with letter F. Hope your wife has a speedy recovery.
                  • 12194
                  • U.S.
                  https://www.youtube.com/watch?v=SIggnQYW_1I
                  • soeren
                    A2442 - No sound over internal speakers and no video playback
                    by soeren
                    I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                    All happened after the battery ran out of power overall several days when I was on vacation.
                    I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                    07-26-2024, 01:24 AM
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
                  • JRade
                    Audio video receiver KENWood KR-V990D,no sound
                    by JRade
                    When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                    The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                    I replaced the capacitor C303/0.047F, nothing changes.
                    I'm asking for help, what should I do next?
                    Thanks in advance!...
                    08-05-2025, 10:23 PM
                  • FrancescoV
                    Onkyo HT-R390 no sound output, video output ok
                    by FrancescoV
                    Good morning everyone,
                    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                    The firmware reported is the following:
                    M:1.00/11107BLP
                    D:?.??/????????
                    O:1.00/11107AL
                    The DSP firmware given the question marks seems corrupt.
                    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                    05-11-2025, 02:59 AM
                  • dikei
                    China Make TV with LG Display horizontal line at top and video freezes 1-3 secs
                    by dikei
                    Hi guys!
                    I'm new to TV repair and just started looking into troubleshooting guides and other online info.
                    Right now I have a Chinese make with LG display that is faulty. If I am not wrong I see two different problems here below.
                    1. There is a line(white/multicolored) at the very top of the display that shows thinner sometimes and slightly thicker in some occasions.
                    2. For any video the play freezes 1-3 secs and at the same time brightness goes low and returns to high when video continue to play.
                    From my initial research...
                    07-06-2023, 11:53 AM
