TV audio output question
  • maxvalutech
    • 804
    • australia
    A customer has TV with only an AV out for audio and has stereo sound connected. This is OK for normal digital TV reception however if he connects an input via HDMI such as Chromecast the audio only plays in the TV itself with nothing to his other setup. I see add ons such as an hdmi audio converter but is there a simple solution otherwise?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: TV audio output question
    Can you use the TV headphone output?
    • maxvalutech
      • 804
      • australia
      He used that on his previous set and was OK. The bigger set now doesn't have a jack only AV out.
      • budwich
        • Jul 2015
        • 3097
        depending on the set and the AV equipment being used, the "normal" method for getting audio out when not carrying it out via hdmi (before it reaches the set... ie. source, av, tv) is to attach an optical cable from the tv to the av equipment to handle digital audio on av equipment not capable of hdmi decoding or over the air audio also.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Go into the USER Menu and check the routing for the Audio Out. Some TVs you have to manually set the Audio Out for each input. Some TOSHIBA YVs are like that.
          • mecha1166
            Copper corrosion? Yamaha HS8S Audio 1 output only
            by mecha1166
            OAUD Yamaha HS8S Audio one output only.
            I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
            08-04-2023, 02:55 PM
          • dicky96
            Denon AVR-X500 No audio output
            by dicky96
            Hi guys, I have this AVR-X500. It has no audio output but if I select some input (DVD) and connect an audio signal to the RCA DVD inputs, I hear a relay click and sometimes there is a slight crackling on the speakers.
            I only have 2x 8ohm speakers attached to Left and Right front.
            If I plug headphones in, the crackling noise stops but I get no audio on the headphones.
            I checked the voltages marked on the connectors on the Preamp PCB (12V, 5V etc) and they are all present. There is also plus/minus 56V on the bridge rectifier on the main amplifier PCB...
            02-22-2022, 08:36 AM
          • FrancescoV
            Onkyo HT-R390 no sound output, video output ok
            by FrancescoV
            Good morning everyone,
            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
            The firmware reported is the following:
            M:1.00/11107BLP
            D:?.??/????????
            O:1.00/11107AL
            The DSP firmware given the question marks seems corrupt.
            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
            05-11-2025, 02:59 AM
          • samson7point1@yahoo.com
            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
            by samson7point1@yahoo.com
            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
            The player processes the audio signal using two different reference frequencies. The "R"...
            04-30-2024, 11:22 AM
          • classicandy
            HP Pavilion 15-N DIS to UMA Conversion done BUT no Audio output
            by classicandy
            Hi All,
            Please, I need help in getting my audio output to work. I did a conversion from DIS to UMA in HP Pavilion 15-N AMD (Model: U92) BUT I'm not getting any sound. I think the audio is tied to the faulty graphics chip. Is there any way i can convert the audio too?
            [MOD EDIT]
            Link to Quanta U92 Schematic - https://www.badcaps.net/forum/troubl...hematic-needed
            08-09-2022, 12:43 AM
