Sony KDL-50w829b
    • 12276
    • U.S.
    #41
    Re: Sony KDL-50w829b
    Maybe check the mlcc caps on driver board for shorts or very low ohms.
    • sordids999
      • May 2013
      • 2161
      #42
      I'll look again but it's been on for 2 hours now and the picture is now perfect
        • 12276
        • U.S.
        #43
        Ok, so gamma issue cleared up then?
        • sordids999
          • May 2013
          • 2161
          #44
          Yes correct perfect picture now
          • t0ny81
            • Jun 2023
            • 5
            If I want to do that, just to check the ribbons, do I need some grounding or similar or is it ok to open the tv without that?
            • t0ny81
              • Jun 2023
              • 5
              Where are those ribbons? Are they under the green and blue board?
              • t0ny81
                • Jun 2023
                • 5
                No worries , there are under the silver tape ��
                • t0ny81
                  • Jun 2023
                  • 5
                  Picture is back now, tape helped, thank you for the video ��
                  • iglitare
                    by iglitare
                    09-04-2025, 07:13 AM
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
                  • CyberPhoenix
                    Issue with picture quality of Sony bravia TV
                    by CyberPhoenix
                    Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                    01-22-2024, 02:08 AM
                  • noisykid
                    Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                    by noisykid
                    5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                    12-30-2024, 07:15 PM
                  • bbrain
                    Sony KD-55AG9 TCON?
                    by bbrain
                    I have this problem with my Sony 55' AG9.
                    It flashes 4x.
                    I have found the service manual, and seems it is the TCON.
                    Before I buy a TCON can someone check the vid?
                    Thanks in advance!...
                    09-19-2024, 10:50 AM
