le40a656a1f vertical and horizontal fading in and out lines
    Hello People,
    I have received from a friend of mine a faulty TV, it's a samsung le40a656a1f, and according to the troubleshooting file in the sticky i suspect the T-CON board to be the culprit, here is a video of the behaviour of this TV:
    https://www.youtube.com/watch?v=2nSP1yZvVIQ
    Now, if the culprit is really the t-con board i am willing to buy another one and swap it, but i read so many stories about people buying t-con board and not having any result or improvement.
    What do you think is the solution?
    Re: le40a656a1f vertical and horizontal fading in and out lines
    Anyone? Any idea?
      Thats a bad panel. Disconnect one ribbon from tcon to panel at a time. See if left or right side works.
        Bad panel.
          It is a panel fault.
          I've got exactly the same set with the identical problem; however if I switch the set on and toggle thought the Source setting quickly, I can get it to display a perfect picture. It does take some time though.
