le40a656a1f vertical and horizontal fading in and out lines
  • starkn
    • Dec 2017
    • Belgium
    Hello People,
    I have received from a friend of mine a faulty TV, it's a samsung le40a656a1f, and according to the troubleshooting file in the sticky i suspect the T-CON board to be the culprit, here is a video of the behaviour of this TV:
    https://www.youtube.com/watch?v=2nSP1yZvVIQ
    Now, if the culprit is really the t-con board i am willing to buy another one and swap it, but i read so many stories about people buying t-con board and not having any result or improvement.
    What do you think is the solution?
  • starkn
    • Dec 2017
    • Belgium
    Re: le40a656a1f vertical and horizontal fading in and out lines
    Anyone? Any idea?
    • freakaftr8
      • Oct 2012
      • 3743
      Thats a bad panel. Disconnect one ribbon from tcon to panel at a time. See if left or right side works.
        Bad panel.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          It is a panel fault.
          I've got exactly the same set with the identical problem; however if I switch the set on and toggle thought the Source setting quickly, I can get it to display a perfect picture. It does take some time though.
          • Stanley1843
            Screen Display Vertical Multicolor Lines
            by Stanley1843
            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
            06-29-2024, 11:54 AM
          • noisykid
            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
            by noisykid
            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
            12-30-2024, 07:15 PM
          • oxi1158
            Toshiba TV 55L6200U horizontal lines + vertical bands. Any hope?
            by oxi1158
            My TV had been showing for the last year some faint horizontal lines on all of its right side, about one out of each 4 of 5 rows of pixels. Not much of a bother, they were unnoticeable when watching a movie. Then, all of a sudden the horizontal lines became much stronger and crossed the whole screen, effectively making it a pain to watch.
            I watched some youtube video where some guy "fixes" it with some tape on the ribbon cable of the t-con, so I tried that, but to no avail. Actually, after putting the TV back together again things worsened: apart...
            10-09-2020, 08:37 PM
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            Sadly it has vertical lines at the left and one line in the middle-right.
            I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
            I have factory resetted the TV as well but also with no luck.
            I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
          • visionbluedemon
            Help. Sony kd-65x85dj vertical lines
            by visionbluedemon
            First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
            Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
            tried blocking LC lines too, but same results
            is it lcd panel issue or tcon board issue?...
            07-25-2025, 04:56 AM
