Sharp lc-49cfg6001k fault diagnosis
  • Madferritt
    • 6
    • England
    Hi.... I am attempting to find which board or if panel may be at fault.
    Symptoms.. plug in tv, solid red standby light, press on, standby light changes to blue and sharp logo appears on screen. After around 20 seconds screen goes blank, power light goes to red and sharp logo comes on again but power light doesn't turn to blue, stays red with no flashing. This cycle keeps repeating.
    I have checked the voltages printed on the power board against the output voltages from the power board to the main board 12v,12v,5v,5v 5vsb, PS(4.5v),5v,5v. The PS voltage is 0v untill I press the on button. The led lights come on when tv is cycling. I have disconnected the LDVS cable from the TCON board and the tv keeps cycling/restarting. The
    TCON board is receiving 12v from the main board. I disconnected 1 of the ribbon cables from the TCON board to the panel and half the screen went bright white, the same happened with the other ribbon cable from the board. As you have probably guessed, it's my first attempt at LCD fault finding so any help pointers would be greatly appreciated. There are no firmware updates on sharp website for this model. It's only 13 months old, got it last Christmas, I can get replacement boards off eBay quite cheap if it's not the panel.
    Regards and thanks in advance for any info... after two days researching I think it may be eeprom problem requiring replacement main board but tbh it's just a guess...
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: Sharp lc-49cfg6001k fault diagnosis
    install firmware you just need to find it
    I suspect a firmware issue dont go looking elsewhere
    • Madferritt
      • 6
      • England
      Ok... i shall research firmware/installation. cheers
      • Madferritt
        • 6
        • England
        after searching on line and ploughing through the forums for several hours i cannot find any firmware or any other info on this model.i
        if firmware fix is not possible, what can i do next?.... TV does not respond to factory reset.
        Will a used main board from an identical model solve the problem?
        • Madferritt
          • 6
          • England
          WooHoo!! I emailed sharp and they emailed the firmware to me, stuck it on a usb stick and up and running....
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Is it possible to share the file.
            • Madferritt
              • 6
              • England
              the file size is 143 MB when compressed to rar using best.i can split it into volumes and upload it unless you can suggest another way, i received the bin file via we transfer
              • Anita_organicartuk
                • Feb 2018
                • United Kingdom
                Hi does anyone have the firmware they could send me for the Sharp lc-49cfg6001k loop problem please....
                Thanks..
                • R_J
                  • 9558
                  I think if you go to Sharp http://www.sharp.eu/av/?s=software+update and enter your serial number, you can download the firmware.
                  • stejones
                    • Apr 2012
                    • 55
                    • United Kingdom
                    any you email me the firmware please if you still have this many thanks
                    stejones22@msn.com
                    • stejones
                      • Apr 2012
                      • 55
                      • United Kingdom
                      Hi do you have the firmware to hand please can you share many thanks
                      • WildPuppy
                        • Mar 2018
                        • 61
                        • Romania
                        Did you try this?
                        R_J: I think if you go to Sharp http://www.sharp.eu/av/?s=software+update and enter your serial number, you can download the firmware.
                        And in case that one failed, this?
                        Madferritt: WooHoo!! I emailed sharp and they emailed the firmware to me, stuck it on a usb stick and up and running....
                        • stejones
                          • Apr 2012
                          • 55
                          • United Kingdom
                          Originally posted by WildPuppy
                          Did you try this?
                          yes tried all the links and it cannot find the firmware after i put in the serial code (c49cf6001k)
                          • WildPuppy
                            • Mar 2018
                            • 61
                            • Romania
                            Are you sure that "c49cf6001k" is your serial no? It looks like a model to me, but I didn't have too much contact with Sharp products. Serial no. is printed on a label on the back of your TV and is usually marked "S/N: <some numbers>"
                            • stejones
                              • Apr 2012
                              • 55
                              • United Kingdom
                              yes it is mate i now have the firmware and i will be uploading the file
                              1. Copy file(s) onto an empty USB memory stick
                              2. You may have a ‘.bin’ file and a ‘.txt’ file if so please keep the .txt file as it is and do not rename this.
                              3. Make copies of the software (.bin) (click on the file, press CTRL + C together on the Key board and then click off the file and press CTRL + V together on the keyboard) so that you have 2 .bin files and rename them (right click on mouse, rename) to the following:
                              a. allupgrade_6486_aes.bin
                              b. allupgrade_6486_aes_U.bin
                              4. Ensure the TV is turned off at the mains plug so that there’s no red standby light on TV.
                              5. Insert the USB with the files into the USB slot of the TV.
                              6. Turn power on at the mains plug so that there is now a red standby light.
                              7. The TV’s Red Light should begin to flash Red to Blue or White slowly
                              8. Once the TV software begins to upload either:
                              a. The TV Light will begin to flash rapidly and then once it slows the update is complete, Leave for 2 minutes then turn the TV off at the mains and remove the USB.
                              b. Or a loading bar will appear and once it reaches either:
                              i. 90 - 100% the TV will turn into standby. Turn the TV off at the mains and remove the USB.
                              ii. 100% Turn the TV off at the mains and remove the USB.
                              9. Return power to the TV and turn on as normal
                              This should resolve the issue you are experiencing.
                              • Andrew F. Ali
                                • Jan 2014
                                • 2450
                                • Trinidad & Tobago
                                "yes it is mate i now have the firmware and i will be uploading the file"
                                Did you upload the file?
                                • stejones
                                  • Apr 2012
                                  • 55
                                  • United Kingdom
                                  https://wetransfer.com/downloads/fa2...ecipient_email
                                  this is for the serial (c49cf6001k) may work others
                                  • stejones
                                    • Apr 2012
                                    • 55
                                    • United Kingdom
                                    i have put a link to it
                                    • Andrew F. Ali
                                      • Jan 2014
                                      • 2450
                                      • Trinidad & Tobago
                                      Thanks for sharing.
                                      • stejones
                                        • Apr 2012
                                        • 55
                                        • United Kingdom
                                        your welcome
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • Rictech
                                          Panasonic SA-MAX770PU SMPSU board fault....
                                          by Rictech
                                          Hello everyone. 😀
                                          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                          There are no devices that have exploded or otherwise show signs...
                                          08-26-2024, 01:05 AM
                                        • tony359
                                          2007 Macbook logic board fault
                                          by tony359
                                          Good day all,
                                          I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
                                          Once the fan was swapped, I installed an OS and it worked fine.
                                          The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
                                          Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
                                          If I see that right, I have missed VCORE on L7100 (page 59)....
                                          01-23-2025, 06:59 AM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
