Sharp lc-49cfg6001k fault diagnosis
  • tom2018
    • Jun 2018
    • uk
    #41
    Re: Sharp lc-49cfg6001k fault diagnosis
    I've had the exact same issue and signed up here to say thank you to the original poster and that I have the firmware if anyone needs it. Message me on here and I'll try and get it uploaded somewhere for you guys... It's ridiculous that this has happened to loads of the same TV all over the place...
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      #42
      It is isn't it? What I think happens is the design fault transcends to the manufacturing time and date and to other models carrying the same board.
      • makeeuropeanu
        • Jul 2018
        #43
        Originally posted by stejones
        Hi Dimitarvelev please send me your email mate happy to send this to you cheers
        Hi, can you send me the file on makeeuropeanu@gmail.com , will be quicker than waiting for sharp to get back to me? Thanks!
        • makeeuropeanu
          • Jul 2018
          #44
          Could you try to upload it somewhere, will be really appreciated. Thanks!
          • iuliantv
            • Aug 2009
            • 36
            #45
            https://drive.google.com/uc?id=1lp7f0ErEAT1HJsZdc4_NxXGFtUfH1uVn&export=download
            • Michaels3e
              • Mar 2011
              • 11
              #46
              Hi guys, I have a question about a sharp TV M# LC-60UD27U This TV when plugged in the front light will stay steady for about 1 to 2 mins and then it goes into the blinking... here's the thing.. it will blink 2 times slow and then 7 times fast .. I cannot find anything on this code I called sharp and they just had me do the reset and the hard reset I think all the resets ave been done but I cannot find anything on this code 2 blinks slow 7 blinks fast .. hope someone can help .. Thank you .. Michael
                You need to start a new thread with make and model in the header, and then upload good clear pictures of the whole backside of the TV showing all the boards, that will be the first step.
                • cossiejay
                  • Nov 2010
                  • 83
                  #48
                  does anyone have a link please the one listed does not work can not be found
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • Rictech
                    Panasonic SA-MAX770PU SMPSU board fault....
                    by Rictech
                    Hello everyone. 😀
                    As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                    Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                    Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                    This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                    There are no devices that have exploded or otherwise show signs...
                    08-26-2024, 01:05 AM
                  • spleenharvester
                    Tower T548006 battery, fault on BMS board
                    by spleenharvester
                    I have two of these spotwash machines. They are portable systems that use a 12V power tool battery consisting of three 18650 cells. One of the batteries recently failed. 12V appears at the terminals but there appears to be a fault condition - machine flashes LEDs when you attempt to power up. When you plug in the battery directly (the machine charges through a USB-C port, but there is a second USB-C port on the battery itself for some reason that can also be used for charging), the green LED lights and a dim red LED lights next to it solid. By comparison, a working battery will flash green only....
                    10-04-2025, 06:33 AM
                  • tony359
                    2007 Macbook logic board fault
                    by tony359
                    Good day all,
                    I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
                    Once the fan was swapped, I installed an OS and it worked fine.
                    The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
                    Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
                    If I see that right, I have missed VCORE on L7100 (page 59)....
                    01-23-2025, 06:59 AM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
