Samsung hd rear projection tv crt subtle wavy lines on displa
  • shelby5041
    • Feb 2009
    • 1504
    • united states of america usa
    This is for the old school tv guys
    Its a 2003 samsung rear projection....crt style tv
    The picture is bright and good color but it has a very subtle vertical wavy lines on the display that seem to change a bit depending on brightness or color of scene..the wavy lines move a bit...not static......almost seems like some type of interference issue...
    Any ideas what would cause this?
    I had tv stored in unheated garage for 6 years...i live in michigan
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung hd rear projection tv crt subtle wavy lines on displa
    Does the picture get out of focus up on bright scenes? Any subtle snapping or popping sounds when pictures change from bright to dark scenes? Does it do this on every input?
    Considering the age of the TV I would start suspecting B+ regulation issues Within the primary side of the power supply
    • shelby5041
      • Feb 2009
      • 1504
      Picture is great...bright....just has these very subtle wavy vertical patterns ..
      Tv is older but remember havent used it in 7 yrs
      Im not wanting to fix it...not worth it...just wondering what would cause the issue
      Its on All inputs...didnt do it on previous tv so its the tv..not the video source
      No popping sounds or any unusual sounds at all while video playing......
      • shelby5041
        • Feb 2009
        • 1504
        If i take a pic and post it...the wavy lines are so subtle the posted pic probably would show the lines
        • shelby5041
          • Feb 2009
          • 1504
          Im trying to find a pic online that looks like my issue
          • freakaftr8
            • Oct 2012
            • 3743
            OK so it's probably not a boost regulation problem but more or less some bad tantalum capacitors and the IF stage. This is the part of the TV that does the frequency modulation to display the image into different frequencies that the circuits can understand. CRT televisions do not use a timing controller or any other circuitry besides a high voltage to low voltage and high voltage flyback transformers, and video processing like Horizontal and vertical oscillators. I suppose the problem could be in the horizontal or vertical output stages or oscillation stages. Snap a picture maybe you would help figure this out
            • shelby5041
              • Feb 2009
              • 1504
              freak how do u and others in here know so much .....did u go to school/traininf for it or learn from job....its awesome....the technical knowhow is hard to believe......im just a tinkerer....have no knowledge of how tvs work internally..
              • linksys1127
                • Sep 2016
                • 121
                Contact Mr. Bob on Avsforum.com. Click on forums and go to rear projection forum. He is the rear projection guru. Look for the title “Don’t dump your CRT RPTV”. Post it there. He helped me out!
                • R_J
                  • 9515
                  Is the problem when using the tuner input or with the video inputs? If the problem is there with the video inputs, that eliminates any R.F. or I.F circuits, also does it effect the menu? many times the video and menu signals are seperate untill they get to the crt video drivers. try sending it a different resolution and see how that effects the problem
                  It most likely a bad cap in the video circuit somewhere, probably one or more of those crappy smd electrolytics
                  Whats the Model?
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    These and Toshiba's were littered with bad tantalum capacitors on the IF modules. Try heating up the video boards with a hairdryer and see if the problem stabilizes.
                    Good call on the menu R_J. I haven't had my head in one of these in a while.
                    I learn what I learn since I was a young boy tinkering. Picking up on hobbies and working in a video repair shop here in Sacramento really helped me out a lot in my teens. Everything I know is self tighten and still learning every day just like this damn OLED that I'm working on
                    • shelby5041
                      • Feb 2009
                      • 1504
                      The video source is the regular video input via rca cables......not the tuner
                      And im not sure if the wavy distortion lines are present when osd is on or not...im not at house with tv...
                      I normally dont even mess with crt tvs anymore since they are obsolete and noone wants them out here but i had one sitting in my garage and my friend needed a tv so i gave it to her yesterday and noticed the wavy distortion interference type vertical lines....very subtle..but if you look hard you see them....
                      Ill look at caps when i can"........all samsung tvs seem to have a lot of issues dont they?
                      • R_J
                        • 9515
                        All it takes is for the output cap on a regulator ic for examble to be weak, and that small amount of ripple at usually a fairly high frequency to get into the video circuit somewhere, and it will show up on the screen.
                        • shelby5041
                          • Feb 2009
                          • 1504
                          Thanks..there are lots of caps on the video and power supply baord...none are visually bulged.all flat tops
                          It does seem like a interference issue like you said ....it sometimes is worse than other times...and it is present even on blue screen with no video input...so i dont believe its a board issue...its probably a cap issue thats doing this....but there are over 30 caps on these boards...maybe ill try to take a pic and maybe someone can point out an area to concentrate on....
                          The lines are actually more vertical but do go on odd angles sometimes....they are about 5-7mm wide and spaced equally about the same...i took some pics will post....
                          • shelby5041
                            • Feb 2009
                            • 1504
                            Here is an image from my tv....the horizontal distortion is due to camera
                            The vertical ones are real....looks much worse in the pic but it shows you what it looks like
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              Looks like rf or chroma issues. Probably an out of spec capacitor for the crystal oscillator.
                              • shelby5041
                                • Feb 2009
                                • 1504
                                freak..which board are these caps on that you think coulb be bad?
                                i cant take a pic.... not with tv now
                                • R_J
                                  • 9515
                                  That is most likely a bad cap in one of the low voltage regulators, It could be from one of the voltages derived from the flyback or it could be from the switching power supply.
                                  It can't be rf issues if you are not using the tuner input. If the color 3.58 osc was off at all you would have no color, if the frequency was off the tint would be out a mile.
                                  The color osc. is phase locked to the video.
                                  Any chance you can provide the Model Number?
                                  • shelby5041
                                    • Feb 2009
                                    • 1504
                                    Model HCN4727W
                                    Its actually a beautiful tv.... i think crt tvs are superior to lcd tvs....no refresh issues and are usually way more reliable and last many years
                                    • shelby5041
                                      • Feb 2009
                                      • 1504
                                      Here is a photo of tv
                                      • shelby5041
                                        • Feb 2009
                                        • 1504
                                        And rpts are kid friendly.....lcd tvs are not kid friendly lol.....crack!!!!
                                          09-07-2024, 05:50 AM
                                        • Rubenlily
                                          Samsung QE50Q67TAU - horizontal lines
                                          by Rubenlily
                                          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                          I'm no expert but I've done the tape...
                                          08-16-2023, 01:12 PM
                                        • jeyoung12
                                          Samsung QN50Q60t lines on screen
                                          by jeyoung12
                                          Hi all
                                          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                          So....i don't know what end of the C ribbon to work with...
                                          02-26-2024, 10:38 AM
                                          09-06-2024, 11:40 PM
