problem Sony KDL46S4100 46 inch lcd tcon
  • dean007
    • Aug 2017
    • 10
    • canada
    hello hope everyone is having a good year so far probably wont last much longer lol
    i have a sony 46 lcd tv Sony_KDL46S4100
    it was having problems the screen went all bleached white the picture was clear just bleached white and all rainbow color looking weird
    so i ordered a tcon board from arizona installed it and ended up with just completely black screen i ordered a bad board okay i order another from shopjimy
    get that install it everything goes okay turn it on and fixed TV great
    then i notice a single line going from top to bottom vertically about 3 inches from the center to the left side acting weird
    its just one pixel width thick vertically from top to bottom and seems odd 2-3 inches up its fine then 2-3 inches it isnt then 2-3 it is on and off thru all the different inputs over air , video ,composite ,hdmi
    its always just the one line everything else seems okay it doesnt seem to affect the on screen displays overlays
    so i guess my question is do i have another bad tcon board or is the screen toasted
    does anyone know is that how some tcon fail just one bad line
    its been 2-3 months now of trying to fix it do i give up and live with the one line burnt out or try another tcon board
    thanks for any responses
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: problem Sony KDL46S4100 46 inch lcd tcon
    If the one pixel wide line is not a bother to the rest of the picture and you don't want to give this one to a friend and buy anew TV. Decide for yourself what you should do. However try cleaning the flat cables from the T-CON to screen with IPA and see if that helps. Could very well be a spec if dust causing your problem.........
    • dean007
      • Aug 2017
      • 10
      • canada
      i did try looking at the connectors closely and wipe them off and tried several different times it might still be the connectors but i even tried moving them while it was on to see if it would change at all it didnt seem to
      uuugghhhh
      any idea do tcons behave that way i still have time to exchange the part for another just not sure anything is going to change worth the hassle to ship it back and forth
      dam 10 dollar a pound shipping in canada
      • budwich
        • Jul 2015
        • 3097
        unplug the tcon to panel cable on the side with the line (with power OFF). power the set back up. what happens to the screen on that side, what happens with the line?
        • dean007
          • Aug 2017
          • 10
          • canada
          okay i did that unplugged the top right flat cable from the tcon
          powered on it came on the right side is still working fine the left side that i unplugged turned all white with a little black on the outer left side
          the area that had the weird acting vertical line is gone and is just pure white with odd horizontal lines
          that not working vertical line seems to light up continually and solid white so white is okay i guess
          it didnt seem to affect the onscreen display in that 8-10 inch segment at the top where the menu is before i unplugged and did this test but i could see that line acting up when the menu was displayed just not in the menu area
          • dean007
            • Aug 2017
            • 10
            • canada
            it doesnt do it on the menu and white all lights up so maybe i got a crappy tcon replacement board ???
            kinda seems odd that the tcon would maybe be working 99.5 percent so close you would think if it was bad or failing it would do something more spectacular
            it definitely just diss appears some times like 50 percent of the time
            that ribbon cable flat cable looks kinda beat up that attaches to the tcon
            maybe the cable is bad it looks like it is only a couple inches long maybe i could try replacing that little 2 inch 100 wire flat cable
            any idea what they call that wire or were i might find one at least its probably a cheap wire
            thanks for the help
            • budwich
              • Jul 2015
              • 3097
              repeat the "test" by unplugging the equivalent cable on the other side. What happens?
              • dean007
                • Aug 2017
                • 10
                • canada
                okay did that plugged the right one back in to tcon unlpugged the left powered on
                left side works okay that one line is still not lighting right when the screen is black its not noticeable but then when source plays its there again
                right hand side is mostly bright white with some darkening black tint on the far right
                • budwich
                  • Jul 2015
                  • 3097
                  OK... so the unplugged side basically looked the same on either side. That kind of says that the lower drivers / edge boards are ok, in general (to me). As Andrew suggested you may not get success. :-(
                  Still more checks. With all cables connected and powered up, locate the panel tab that seems to correspond to the line in question (ie. proximity).... using your finger or pencil with eraser, light press on the tab near the glass / contact area and see if anything changes with respect to the line. Be careful as the tabs are only "thermally glued" down and the contact area is very fine. Go from there.
                  • dean007
                    • Aug 2017
                    • 10
                    • canada
                    so then you think the tcon is okay then
                    sucks the first one i got didnt work now i have 0 zero tcon faith lol
                    yeah when i did the tcon test thing it acted the same when i did either side basically 90percent solid white with some darker blackness on the outer edges
                    • budwich
                      • Jul 2015
                      • 3097
                      "so then you think the tcon is okay"... I didn't say that. It could still be a problem but I think a singular vertical line usually isn't a tcon issue as I don't believe it can make that happen... but maybe.
                      The greatest potential might be a poor connection. Further, when you say "i did try looking at the connectors closely and wipe them off"... which connectors are you talking about? NOTE: a "cable" has TWO ends... :-)
                      can you post a picture, focusing on the connections / connectors in question?
                      • dean007
                        • Aug 2017
                        • 10
                        • canada
                        i just cleaned the two white ribbon connection cables coming into the top of the tcon thats all i did not undo the other end of the cables going into the i believe h1 board under the top power volume controls
                        i think i would have to take the tv completely apart to get to the other end of the ribbon cable i can see the connector but i cant tell how it opens
                        • budwich
                          • Jul 2015
                          • 3097
                          No problem, I don't actually know how they are terminated at the "other end" BUT from my limited experience, IF they are unclampable, it is possible that there may be a slight issue there for what ever reason. Yes I know from my sony 46 experience, you have to take a few things off to look / get at the other end.
                          Anyways, you likely have to go in that direction IF you want to check the tab areas to see if there is any impact on the issue by touching / pressing on them.
                          I am somewhat "unsure" of your "solid white with some dark blackness" observation... hmmm. can you post a picture of this?
                          • dean007
                            • Aug 2017
                            • 10
                            • canada
                            when i unplugged the tcon the half i unplugged turned completely white in the center then as it went out to the edges the last 2-3 inches where darker black and kinda wavy like a picture frame just distortion i assume
                            it seemed to react the same way when i did either side
                            im just debating if its worth continuing to try and fix it more
                            i looked up or tried to find the little 2 inch ribbon flat cable i could only find one with a close part number but not the actual part on ebay guy wanted 16 for the 2 inch cable and then 21 dollars for shipping and in the add mentioned it has to be the exact right part
                            and the net had like no matches for the exact part so i guess i just suck it up and enjoy 99 percent of the tv once a person is back 5-10 feet from it it will probably not be noticeable by anyone but me
                            and ill just stare at it constantly remembering how i failed hahaha
                            just sucks if its the dam tcon and i could get anotherone shipped out and have a perfect tv again
                            maybe i should just leave it on for couple days straight and see if it acts up more
                            • budwich
                              • Jul 2015
                              • 3097
                              well, your experience with tcons hasn't been good so far and I for one have never replaced one so I can't say much else.
                              I would suggest posting a picture of what you are looking at... if you can choose a test pattern that people know and can readily see issues with if there is a problem.
                              I guess if the "tcon supplier" has no problems sending you a replacement, then you have nothing to lose with getting another one but I doubt it will help.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4541
                                • Italy - Milan
                                Hi, sorry i don't have read all the last posts, it's ery heavy for my engish, no punctuation..
                                I don't figure out well the defect, please can you post a pair of pictures, magnified, with and without the menu in the middle of defect, but i think is a matter of mainboard, maybe some metallic particle have finished under it by error.. or a smd capacitor have flewt away..
                                • dean007
                                  • Aug 2017
                                  • 10
                                  • canada
                                  i would take a picture but im not really sure its going to even show up in the picture its just one single pixel width about 3 inches off center on the left half and goes from top to bottom of the screen it doesnt do weird stuff just doesn't seem to be able to make all the colors seems it can do white and black okay and gray the menu color
                                  unless someone knows about tcon failures and figures thats what it is
                                  i could try another tcon
                                  but taking the tv apart even further doesnt seen to be worth it
                                  those flat ribbon cables and connectors really dont like being messed with they made that stuff cheap as crap 2-3 in and outs and your gonna have problems
                                  the connectors start lifting from the wires there hard to line up and if you break one good luck finding the right part ever
                                  i looked up just a little 2 inch flat wire and guy wanted 35dollars total
                                  sometimes you gotta know when to fold em i guess im going to have to live with 99.23765521 percent of the tv working
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4541
                                    • Italy - Milan
                                    So the pictures?
                                    • nomoresonys
                                      • 12330
                                      • U.S.
                                      So did you try this? it's to help see if it's a tab bond issue.
                                      • Daren87
                                        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                        by Daren87
                                        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                        08-13-2023, 03:25 PM
                                      • iglitare
                                        Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                        by iglitare
                                        i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                        Backlight seems to work, Sound (Setup menu after reset) works.
                                        If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                        Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                        With my small knowledge i would think at least the cables are good.
                                        Can this happen because of a bad tcon board?
                                        Or is it always a bad/shorted...
                                        09-04-2025, 07:13 AM
                                      • kca
                                        by kca
                                        Hello all ~
                                        08-31-2025, 06:38 AM
                                      • rimwall
                                        Sony KD-65x7500D - double image - Tcon or Panel?
                                        by rimwall
                                        This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                        I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                        11-18-2025, 02:09 AM
                                      • thelankanguy
                                        Sony KD-55X9000F TCON Issue
                                        by thelankanguy
                                        The TV shows a black screen with no image.
                                        TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                        Later both ribbons were disconnected and TCON voltages were tested.
                                        12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                        There is also a short to ground in this circled inductor.
                                        Is this a TCON issue or something else ?...
                                        12-13-2024, 12:27 AM
