Samsung UN65HU7250 T-CON voltages?
  • 00steve
    • 8
    Hello all, I have a 65" Samsung that has backlights and sound, but no picture. I recently purchased a used t-con board off ebay, and it didnt help. I have over 12 volts on both fuses on the tcon board, and the old board didnt have much of anything on the test points going to the panel. New board has a couple of the panel side points with 3 volts, but almost all the rest have less than half a volt.
    From what research Ive done I think its supposed to have more than that? Could it be something from the main board thats not getting through?
    I took a video of the tests, thanks for your help!
    https://youtu.be/83Z-s9aAf5I
  • thoma
    • Sep 2012
    • 268
    Re: Samsung UN65HU7250 T-CON voltages?
    WAIT UNTIL GET MANUAL APPEARS!!!!!
    • 00steve
      • 8
      Thanks for that, I learned a lot from it. I still have no idea what the voltages on a good t-con board would be, that manual didnt give them to me. I am pretty convinced that I just got a bad board from ebay.
      • budwich
        • Jul 2015
        • 3097
        I think you need to verify voltages that are printed on the boards (usually around the connectors) to what they are supposed to be versus what they especially with respects to the main board and power supply. Note: that voltages at the tcon may not "be there" because the main has shut down the system for some reason.... depending on what that pin represents.
        As a side test, you can try unplugging the tcon to panel cables on one side (one or two since it appears to have 4) and turn on the set and see what the result is. Do the same test, with the other side and see the result. Depending on the result, you can go from there hopefully.
        • tomstr
          Tommy
          • Jun 2010
          • 147
          • Usa
          I have a similar model but my tv is a UN60HU8500 SAME PROBLEM... can you please contact me ASAP??
          • thoma
            • Sep 2012
            • 268
            https://cdn.badcaps-static.com/pdfs/...e27f7a8ad9.pdf
            • tomstr
              Tommy
              • Jun 2010
              • 147
              • Usa
              Please contact me i have almost the same model
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4458
                • Italy - Milan
                tomstr what do you say? We are here for free, we can't do service for just a single person! The help is done here and stop (unless you pay for a consult). To steve, have you tried TP voltages with panel disconected or half disconnected?
                • 00steve
                  • 8
                  Well, I have done the disconnecting the board on half of it trick, but I havent been able to get any picture on either side. Not real sure what TP voltage means, thanks
                  • 00steve
                    • 8
                    Ha, nvmd I will try to test voltages with it half unplugged.
                    • tomstr
                      Tommy
                      • Jun 2010
                      • 147
                      • Usa
                      I'm not sure what your asking? I did not ask for help!! I am only trying too see if we have the same problem? So you may want to explain?
                      • 00steve
                        • 8
                        Ok voltage is same plugged into the panel or not.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4458
                          • Italy - Milan
                          I'm sorry tomstr, my english not good, when you say "YOU" i understand ALL US.. but you refer only to the OP, now i know...
                          to steve: that is not the way of testing a tcon, the most important thing is that Panel and master ICs are correctly power supplied.
                          then if you want you can test in volt all the capacitors except the very very little ones, then report here the tensions, do not tell where you tested and don't repeat tensions if them are near equal. Test both sides.
                          • 00steve
                            • 8
                            I am not sure how to test to see if the panel is correctly power supplied, I thought that is what I was doing in the video? Also, I am not sure what the voltages should be on the test points. Videos of other tcon boards have more than 1 volt on those test points, mine has about a half of a volt. I'm confused.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4458
                              • Italy - Milan
                              If you have testpoints with name at side, write them here and the V reading..
                              • 00steve
                                • 8
                                Ok, one more question before I do that, when the tv is on, should there be power at the coils? I dont get anything on any of them.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4458
                                  • Italy - Milan
                                  Yes the inductors have to be at a certain voltage, If the board is someway "disabled" you have to read 12v at least on the coil that make voltage boost. If so tell us the tcon marking so i search for a picture, so i point you which is the multi pwm genereator chip.
                                  • Hakuu
                                    by Hakuu
                                    Hi There,
                                    More Details
                                    TV Model - LG OLED77G1PUA
                                    07-12-2023, 02:37 PM
                                  • m1ch43lzm
                                    by m1ch43lzm
                                    05-12-2025, 08:37 PM
                                    09-07-2024, 05:50 AM
                                  • Asraf Atb
                                    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                    by Asraf Atb
                                    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                    01-27-2025, 05:02 PM
                                  • valvashon
                                    Samsung UN65KU6290F PS board blows fuses
                                    by valvashon
                                    Samsung UN65KU6290F (May 2017); received from local Buy Nothing group. Was listed as "just went dead" and they wanted it gone. I brought it home, didn't notice anything visually wrong with the power supply board, looked up the cost of a new one and that's about as far as it went. Family was tired of tripping on the foot of the set so I decided to dig in and repair or toss.
                                    Can't believe that I didn't check it earlier but I found the main 8 amp fuse blown. Jumped across it with a 10 amp blade style fuse and you can see that it literally exploded inside the second I plugged...
                                    11-27-2023, 01:09 PM
