Vizio ADTVD3613XA6 PS for E500I-B1 oops help!
  • kick7
    • Dec 2017
    • 6
    • usa
    Hey guys I've been repairing this PS board for a relative and after reading all the threads about this model and looking at the great circuit drawings budm had traced out for others I thought I had a good chance of fixing it. Started with the usual TV will not turn on, power button lights then fades out. found 5v SB at 5.13v B+ at 170v with set off all other pins 0v. After pushing power button no change except ps_on 2.95v no other change. found IC9101........LCS703LG and IC9801.........LD7591 both get vcc from ps_on by way of q9101 thanks to budm and his tracing! found vcc very low at both chips and IC9101........LCS703LG was pretty hot so i removed it and B+ at 393v its looking good figured I'd replace IC9101 and IC9103 and it would run. Well no 5vsb 5.13v, B+ 390v, Dim .056v, on_off 3.32v, ps_on 2.95, but 12v is only 6.97v and 24v which from what i've read is really only 16v is 9.07? its working but feedback or regulation is bad? I better look some more hmmm......Oh crap this is where I hope one of you can help me avoid complete humiliation. It seems that while putting IC9103 in I Whoopsied R9122 right off the board! If someone knows that resistor value I'd be grateful. thanks
  • kick7
    • Dec 2017
    • 6
    • usa
    Re: Vizio ADTVD3613XA6 PS for E500I-B1 oops help!
    Maybe someone who understands this part of the circuit better than me can give me a reasonable value to start with and I'll change it until it's right. I'm thinking they use this shunt regulator instead of a zener?
    • kick7
      • Dec 2017
      • 6
      • usa
      I found a full service manual for it so
      I answered my own question 10K. So now it turns on and everything seems to work but still one issue the backlight flickers a bit
      • dskall
        • Oct 2016
        • 2905
        • usa
        All backlights flicker or just one? If just one probably led going out.
        • freakaftr8
          • Oct 2012
          • 3743
          Check out n801 lcs703lg IC under heatsink power supply
          It's probably faulty. Ran into this before.
          • Ward Thomas
            • Jun 2018
            What did you do to fix this TV? I have 3 of that model and all 3 do as you described. Power light is on, fades but TV will not turn on. I have to unplug them, hold the power button down for about 20 seconds, leave them unplugged for hours, plug back in, then they will power up.
            • pomonabill221
              • Mar 2016
              I have this TV also. Where did you find the service manual or schematic?
                • 12206
                • U.S.
                There's a picture of it from sj, maybe someone with a beefy graphics card can make out the numbers? https://www.shopjimmy.com/vizio-adtv...pply-e500i-b1/
                • R_J
                  • 9556
                  R9122 is a 10K 1/8W 1%
                  You may want to replace C9305, C9308 C9122 and C9805 these are the caps on the ic's vcc supply, if they are weak the power supply may not turn on all the time.
                  • SS454
                    vizio e650i-a2 backlight flashes then turns off
                    by SS454
                    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                    panel: au optronics T650HVN05.4
                    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                    https://www.shopjimmy.com/vizio-56-0...-power-supply/
                    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                    08-20-2020, 03:57 PM
                  • mrtek
                    Vizio M65-C1
                    by mrtek
                    Hi.
                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                    07-14-2025, 07:28 PM
                  • howardc64
                    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                    by howardc64
                    Failure Symptom
                    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                    Where is the short?
                    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                    05-27-2025, 02:56 PM
                  • howardc64
                    Vizio SmartCast TV software bug that looks like hardware
                    by howardc64
                    Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                    It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                    11-16-2024, 05:17 PM
