Sony XBR-65X810C Bad Panel?
  • toddw65
    • Jan 2014
    • 108
    Happy New Year y'all!
    I was given this 65" Sony 4k tv that is less than 2 years old. When I first got it, the picture did display on all settings, but had an overall blue tint to it and a 4" wide blue vertical bar through it. After pulling & cleaning ribbon cables and reseating them, the picture no longer displays. The panel just shows blue and the vertical blue bar is still there. Sound works and remote functions also seem to work.
    Thoughts?
  • budwich
    • Jul 2015
    • 3097
    Re: Sony XBR-65X810C Bad Panel?
    IF I didn't know better, I would say that's the old... "blue screen of death" ... aka microsoft operating system locked up... :-)
    Probably try and see if you can find some factory reset sequence.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4459
      • Italy - Milan
      You have 3 chances: make a better picture of tcon at sunlight, or clean away that pencil marking on the board model that someone have stupidly covered, find all the test points (ex. VCC18, VCC33, VDD) and test them in voltage an report, also the main fuse.
      LAstly i think the model number is not correct, i think it begins with KDL-----
      • toddw65
        • Jan 2014
        • 108
        Updates and things I should have added in my OP:
        This is a replacement TCON from Ebay since that was my first thought and they are relatively cheap. I'm assuming that the markings on the board are QC.
        Main fuse is good. TCON fuse is good.
        All pb/tcon voltages that should be 12v are 12.6vdc. Logic voltages are all at 3.4v except TCON_ON which reads 2.8v
        Model number is correct. Attached a couple more pics.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4459
          • Italy - Milan
          PLease don't use too much acronyms, i don't understand "QC", "pb/", it doesn't matter too much logic signals on tcon, first of all must see supply voltages, have you checked testpoints (TP) = VDD(15v), Cathode of big D5(15v),Vcore10(1v),VCC18(1,8V),Vcom1-2(7v?),
          Vcc33(3,3v),VGL1-2(-6v?),HVDD(7,5v),VGH(27v)
          • dskall
            • Oct 2016
            • 2905
            • usa
            Pull one ribbon to panel cable at a time and see what you get
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4459
              • Italy - Milan
              If have wrong tensions disconnect ribbons one at a time and retest.
              • freakaftr8
                • Oct 2012
                • 3743
                This is a quirky model I'm dealing with the 75" version. Did you remove the cables from the main board to the tcon and and have the TV powered up at any time? Is power light flashing green and yellow at all?
                • toddw65
                  • Jan 2014
                  • 108
                  Sorry. By QC I meant that the markings on the board are probably from quality control at the manufacturer. As for pb, I just meant power board.
                  All the output voltages coming from the power board at CN6401 appear to be correct.
                  All 12VREG are at 12.6V and all other voltages at that connector are at 3.4v except TCON_ON which is 2.8V
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Just read your last post. Reload firmware via USB go to Sony website copy firmware and unzip to USB root drive put the firmware USB into the USB port on the TV and turn the TV on and let it sit for about 30 minutes. You will get your picture back. Once we get there we will research this line problem.
                    , It appears that the main board copies all serial numbers or something from tcon And if that ID does not match upon start up it will not power the tcon.
                    • toddw65
                      • Jan 2014
                      • 108
                      Ok. I did the firmware upgrade and I *think* it went ok. USB drive was flashing and the power lights flashed blue/green for a little while and then the tv rebooted and started back up but still no image. Everything on the tv seems to work except the video. It connects to my wifi and I can cast audio/video to it with my phone, control the volume, etc. I downloaded the Sony remote app since I don't have the actual remote and based on audio cues and screen flashes, I can tell that the all of the remote functions work.
                      I tried disconnecting the ribbons from the tcon to the panel boards and the action of connecting & disconnecting them sometimes caused the screen to show different shades of blue and at one point half of the image actually came up but disappeared again. I'm sometimes able to get it to sometimes show the whole screen as solid blue without the vertical blue bar/line showing up, but none of the results of are repeatable when pulling & reconnecting the cables.
                      • budwich
                        • Jul 2015
                        • 3097
                        how is the side tab bond cables coonected to the bottom edge boards?
                        further please provide a bit more on your "disconnected the tcon to panel" testing. With one side disconnected, please post a picture of the display. Repeat the test with other side... again with a picture. There is something strange IF when you disconnect the tcon and the panel hasn't changed its "response".
                        • toddw65
                          • Jan 2014
                          • 108
                          I'll get some pics of the edge boards and of the screen with each side of the tcon disconnected tomorrow.
                          Thanks.
                          • budwich
                            • Jul 2015
                            • 3097
                            i am assuming "bottom" but they could be along the top depending on configuration which isn't obvious from your pictures of the back/cards.... but you get the idea.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              As per what Davi.p is mentioning, you need to check these voltages around the outputs ribbons that go into the panel. Loom for the little testpoints. They are labeled as such. There's a good possibility that some capacitor went short circuit on one of the panel boards attaches to the LCD panel.
                              • toddw65
                                • Jan 2014
                                • 108
                                Ok. Got a chance to get some screen pics with the tcon ribbons to edge cards both connected vs connected one at a time. Also adding some pics of the panel edge boards. Also was able to get voltage reading from the tcon with neither ribbon connected, both connected and one at a time. Now I need to find & check the test points on the edge boards. Man those are tiny.
                                Code:
                                	TCON Cable Connected
                                	Neither	Both	Left	Right
                                VDD	0	16.37	16.36	16.37
                                D5	12.66	16.4	16.36	16.38
                                VCORE10	0	1.04	1.04	1.04
                                VCC18	1.77	1.8	1.76	1.77
                                VCOM1	0	6.12	6.11	6.11
                                VCOM2	0	6.12	6.11	6.11
                                VCC33	0.71	3.28	3.28	3.28
                                VGL1	0	-5	-4.98	-4.98
                                VGL2	0	-9.91	-9.9	-9.9
                                HVDD	7.92	7.92	7.91	7.92
                                VGH	0	28	28	28.1
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  it would be nice if you would have "titled" your picture with a bit of description so we know what we are looking at. Can you actual do that now in words.
                                  my guess right now is your voltages to your backlights (leds) is not right... maybe.
                                  further, I hope you aren't disconnecting / connecting cables with the power on.
                                  certainly the white line off center is cause for "despair". With the tcon disconnected from one side, I am not how anything can happen on that side besides either black or all white... maybe its a sony thing.
                                  I was hoping that to see a disconnectable cable on the edge boards either going between bottom boards or between the bottom and side... but I don't know what I am looking at in those pictures. :-(
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    This is interesting. I would say either your tcon is not interpreting signals from mainboard or mainboard is bad. Most likely tcon. However, that line in the screen is bad panel, gate driver. Try pressing on gate driver where it imbexs into panel and see if that line goes away.
                                    • toddw65
                                      • Jan 2014
                                      • 108
                                      Sorry about the previous pics sans description. I was trying to get the detail of the edge boards and didn't think to get the overall picture. Here's a couple of pics with a wider view that should help.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4459
                                        • Italy - Milan
                                        Hi, the tcon voltages are surely all in order, the strange thing in Sony tvs, like freakaftr8 thread, is that with panel disconnected tcon is "disabled". For the last pictures of video i guess n.1 is with no panel connected, n.2 right half connected, n.3 left half.
                                        I don't agree with budwich, is surely not a backlight problem.
                                        I don't agree with freakaftr8 when he says bad side driver for that vertical band, vertical things are pertinence of source drivers (the horizontal tabs). Or it can be corrosion,
                                        for instance my thought is bad panel for visibly corrosion on the central right tab visible on the second "panel's board" picture (that white substance)
                                        MORAL: "never wash tvs like a car"..
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
                                        • r3vsEngIT
                                          Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
                                          by r3vsEngIT
                                          65x900h with the panel from a 65x930d.
                                          900H: model yr 2020, Samsung panel
                                          930D: model yr 2016, Innolux panel
                                          spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
                                          the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
                                          07-11-2023, 11:11 AM
                                        • guidodroid
                                          Bad Panel in Sony Bravia X850G
                                          by guidodroid
                                          Hello all,
                                          I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
                                          It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
                                          Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
                                          The issue is not as bad as others that I've seen around, but is indeed noticeable...
                                          03-19-2022, 12:08 PM
                                        • AK_777
                                          Sony KD-65A1 Repair – 4 Red Blinks Error
                                          by AK_777
                                          Hi everyone!
                                          I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                          Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                          02-20-2025, 04:15 PM
