Re: Sony XBR-65X810C Bad Panel?
I was kind of joking about the backlights... I don't think they would be "blued" with a voltage difference.
So.... a couple of questions.
when OP is disconnecting the tcon to panel cable... are you disconnecting at the edge board or at the tcon. Disconnect at the tcon IF those are clampable cables (I can't tell). Repeat you test (ie. disconnect one side ... and then do the other). Any change?
Next, the bottom boards have a "bridge" cable... interconnecting halves of the bottom.
IF they are unclampable, connect up your tcon cables but now disconnect at those aftermentioned cables. Anyways difference?
