The Misery of Vestel Corrupt Firmware - Many Questions! (17MB95M - Hitachi 42HYT42U)
  • cheeky2
    • Dec 2012
    • 337
    Re: The Misery of Vestel Corrupt Firmware - Many Questions! (17MB95M - Hitachi 42HYT4
    A small point that may evaded you is that they do two different versions of power supply and main board for this model! This is as a result of them having two different screens in them!
    So this maybe why your main boards are not behaving as they should! If you have inadvertently mixed up the boards! Which might explain why you have had so many issues with so called working boards?
    This I have found out after purchasing a broken screen model of this TV to find out its a different screen and leds inside! I was after the working leds which were different from the first TV of the same model number.
    • reessi
      • Jan 2016
      • 334
      Interesting, screen is gone now, still got all the boards somewhere. I did measure the voltages coming from the board though.
      Also I got it to stay on (blue led but black screen with backlight) by flashing a different firmware.
      All very confusing.
      • reessi
        • Jan 2016
        • 334
        And one of the boards I bought the seller had pictures of it fully working on a cracked screen so that tv sent me crazy....
        Wasted so much time on it.
        • cheeky2
          • Dec 2012
          • 337
          One of the boards use a 17IPS20 PSU and the other uses a 17IPS71 PSU. The 17IPS71 uses the screen VES420UNDL-2D-N03 which uses 36leds in the panel.
          The 17IPS20 panel is a VES420UNDL-N01 which has 48 leds in the panel.
          So the power supplies have different voltage output with each other.
          There is around 36V difference which would explain why your boards were shutting down! So the firmware of the main boards were probably OK just the psu's were wrong for the panel. If the original psu was swopped over with the incorrect one then you were on a hiding to nothing or even if the 17ips20 psu was changed for a different variant you would have been in the same situation.
          The power supply was probably shutting down your leds and turning the TV off! Result being you concluded the main board firmware was at issue!
          Just read and found that you had the VES420UNDL-2D-N03 which uses the 17IPS71 psu which can have failed diodes on them. It should have the 23224752 on the white label if it is the correct one for the TV?
          It might be worth checking to see if it's correct at least that way you may get some understanding as to what was happening.
          • reessi
            • Jan 2016
            • 334
            Cool, I have all the boards so I will dig them out and report back...
            Cheers.
            • cheeky2
              • Dec 2012
              • 337
              #26
              The correct main board for it should be a white label with the following numbers:
              10093507 23225762
              Just so that you can verify the main boards purchased are correct.
              • cheeky2
                • Dec 2012
                • 337
                #27
                Just had one come in and the 17ips20 psu has a larger connector on the main board which means that you couldn't confuse the main boards as one of the mains is a 17mb95 and the other is a 7mb95m.
                So my thoughts on this are incorrect!
                My only conclusion is the firmware has various versions which is normally shown on the label of the board ie v3.6.3j and v3.2.9r latest version is the highest number. This information can be found on the white label on the main board.
                Its possible that the files you were trying to get were from different versions of software.
                • Bazilwrc164
                  Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                  by Bazilwrc164
                  I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                  The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                  I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                  If anyone can provide:
                  • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                  • Or a compatible EEPROM dump
                  07-23-2025, 12:15 PM
                • MF ELETTRONICA
                  Hitachi 32HB4W56I NAND Firmware
                  by MF ELETTRONICA
                  Hi guys, have a nice day. I wanted to ask if anyone has the bin file for this nand MT29F4G08ABAEA. I'm attaching the model of my TV, the motherboard and the panel number. Please, if anyone can help me, thanks.
                  11-28-2024, 02:35 AM
                • dragometin
                  Hitachi 40HYC42
                  by dragometin
                  TV Model: Hitachi 40HYC42
                  Power Supply: 17IPS71
                  MainBoard: 17MB95M
                  Panel: VES400UNDS-2D-NO3
                  When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                  I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                  Is there any variants on 17IPS71 power supply's?
                  UART output pins 10 and 12 on scart connector:
                  Code:
                  12:24:04.595
                  08-08-2024, 05:53 AM
                • tranquility
                  Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                  by tranquility
                  i want to repair an Onkyo TX-NR809 receiver.
                  symptoms:
                  on power on, display appears and i hear one click. enue functions is given.
                  - no hdmi output
                  - audio output not tested, but i think it is not there
                  - usb sticks are not recognized
                  if i read out the chips with display+standby button + tone+
                  both dts show only ????
                  chip is D830K013BZKB4
                  things i have done:
                  - reflow of the dts chip without taking off and reballing
                  - changed the aluminium caps without the big one with 25v because i dont...
                  08-25-2025, 01:04 AM
                • mattpd
                  PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
                  by mattpd
                  PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
                  No LM damage. UART gives a generic "APU not responding" error.
                  Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
                  I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
                  So to those with experience, would you expect at least a little heat from the NAND during...
                  09-02-2025, 09:42 AM
