Hitachi 32HB4W56I NAND Firmware
  • MF ELETTRONICA
    • Jun 2024
    • 38
    • italia
    Hi guys, have a nice day. I wanted to ask if anyone has the bin file for this nand MT29F4G08ABAEA. I'm attaching the model of my TV, the motherboard and the panel number. Please, if anyone can help me, thanks.
  • massimomax
    Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
    by massimomax
    Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende piΓΉ,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
    spero che qualcuno puΓ² averlo per riprogrammare eprom. grazie
    Post in English !!!
    I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
    02-28-2025, 07:27 AM
  • PNI E.
    firmware hitachi 50hk6000 mainboard 17mb130s
    by PNI E.
    hi guys, can you help me to find a firmware for my hitachi 50hk6000. the tv turns on but no screen, im sure it s a firmware problem because i bought a new main board from ebay but they gave me an other version of the mainbord mine finish in s the board they gav me finish in p, and have 3 hdmi, but the tv with that board turns on but says dont signal and doesnt respond to the remote control. so someon can give me the firmaware for 50hk6000 main board 17mb130s so i can flash the eprom thansk guys
    02-14-2025, 02:06 PM
  • duwane
    A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
    by duwane
    Hi All.
    Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
    The issue:
    Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
    10-26-2022, 07:02 AM
  • dragometin
    Hitachi 40HYC42
    by dragometin
    TV Model: Hitachi 40HYC42
    Power Supply: 17IPS71
    MainBoard: 17MB95M
    Panel: VES400UNDS-2D-NO3
    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
    Is there any variants on 17IPS71 power supply's?
    UART output pins 10 and 12 on scart connector:
    Code:
    12:24:04.595
    08-08-2024, 05:53 AM
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
