Philips 58pfl4609/f7 TV not working
  • drabina
    • Dec 2017
    • 13
    I have Philips TV model # 58pfl4609/f7. I got it for free (not working of course) and I am trying to trouble shoot the issue. The TV has three boards and if with your help, I could diagnose which board is faulty, I would most likely replace the whole board. So far, the symptoms are:
    1. No power at all, no standby light, no flashing lights, backlight doesn't turn on.
    2. Standby voltage on the power supply is at exactly 5V
    3. No other pins (12,24V) show any voltage
    4. Pressing Power button does nothing
    Could somebody help me out figure out which board is shot by providing info on what to check next?
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Philips 58pfl4609/f7 TV not working
    Without any further testing, this would point to the main board. I can't read the pins on the connector going from the power supply to the main board but it would be smart to check the PS-ON pin as the power button is pressed. If you have no or little voltage on that pin, then the main board is almost certainly the culprit. Make sure if you order one that you get an exact match. Usually there is an identifier on the white sticker that shows the board version. Don't order by the model number alone as there may be multiple types.
    • drabina
      • Dec 2017
      • 13
      Thanks for replying.
      I have the following pins on the PS board:
      Smaller connector:
      175V
      175V
      NC
      GND
      NC
      SP
      NC
      ADJ
      ENA
      Bigger connector:
      12V
      12V
      GND
      GND
      12V
      5V
      GND
      5V SB
      GND
      STB
      GND
      ADJ
      ENA
      I do not have PS-ON pin or I do not know where to find it.
      • freakaftr8
        • Oct 2012
        • 3743
        I believe ENA is ps_on. Sounds like mainboard as well.
        I believe ENA,short for enable.. and that 175 v on small connector, that should be 17.5v
        • drabina
          • Dec 2017
          • 13
          There is no voltage change on the ENA pin on the bigger connector. I just forgot to check the voltage on the smaller connector (ENA pin) on the PS. Will do that later today when I get back from work.
          • drabina
            • Dec 2017
            • 13
            Still need help guys. I have purchased a replacement main board but that didn't fix the problem when installed. Same symptoms (5V on standby, no other voltages present, no lights on the TV). When I unplug the TV, wait a bit and press Power button while connecting the power cable, I get 4 green light blinks. Any ideas?
            • drabina
              • Dec 2017
              • 13
              Anybody?
              • freakaftr8
                • Oct 2012
                • 3743
                You say their standby voltage you have a SB5V and an STB pin. Test each pin in its current state and post the findings.
                Also what's the voltage at the primary capacitors on hot side of power supply when in standby?
                • drabina
                  • Dec 2017
                  • 13
                  Sorry for a delay in responding. Here are the measurements:
                  SB5V - 5V
                  STB - 0V (no reading)
                  Capacitors - 168V (those are the big long capacitors on the PS board)
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Nothing on the 17.5v when you press power button?
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      I think STB is your ps_on
                      • R_J
                        • 9535
                        Have you checked the small round (red) fuses F2,F3, on the power supply board, I see shopjimmy has a repair kit for this board, maybe check the fuse resistors like R48 & R15, they should read very low and not open.
                        Yes it looks like STB is power supply on
                        • thoma
                          • Sep 2012
                          • 268
                          https://www.amazon.com/Philips-UPBPS.../dp/B0772T8WYH
                          https://www.shopjimmy.com/philips-58...repair-kit.htm
                          • drabina
                            • Dec 2017
                            • 13
                            Nothing on the 17.5V when I press the power button. The round red fuses read 0.1 Ohm on all three of them (F1, F2, F3). R48 and R15 resistors look good too. Could it be the power board? The replacement main board was pulled from a working TV with broken screen so unless it got damaged during shipping, it should be working. I have also noticed that some of the wires go from the main board to the power board thru the LED board. Anything to check on that board?
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              I dont have specs on this power supply but if mainboard was not the issue, there's a possibility that mainboard is trying to bend the turn on command bit the power supply has a problem with turning on.
                              While pressing the power button no you get any voltage change at STB?
                              • drabina
                                • Dec 2017
                                • 13
                                No change at any of the PINs on the power supply board. I have even checked with the remote to make sure button is not the issue.
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Are you getting any voltage the input and power buttons via the small flat white ribbon cable?
                                  Also monitor your 5v standby when you press power button.
                                  • R_J
                                    • 9535
                                    remove cn3 going to the main board, then jump +5vsb to stb, that should turn on the power supply if its working, it looks like it has a series resitor (R71) so no external resistor is needed
                                    R77 goes from that line (after r71) to ground holding Q8 base low in standby condition
                                    • sirentech
                                      • Apr 2021
                                      • 8
                                      Hi, I am new here but have been a viewer for quite sometime. Thanks for having this multitopic forum. I also have the Phillips 58PFL4609 flat screen.
                                      It does have a power supply issue. Here is what I can inform you, and I am hoping someone knows where I can find a schematic. Manualsunlimited does not have this one. Anyway, ShopJimmy does carry the repair kit for this for COMMON problems only. I have also read that the kit does not resolve all the issues with regard to no-start and maybe no standby. On the underneath of my board I have 2 smd zeners and 1 or 2 smd transistors that are shorted. On the top side one of the MOSFETS are shorted as well. I am hoping someone has a diagram so I can identify what the zeners breakdown voltages are. I have no problem sharing what I have found out with regard to bad components. Also, it is quite disappointing to look around the iNet and see the excruciatingly painful prices for that PSU. I was very interested in the business that advertises they will upgrade the board to non-inferior parts. Anyway, thanks for any help one may provide.
                                      • tzap
                                        • Mar 2023
                                        Old thread, but bumping it because I have the same problem.
                                        Symptoms were: No signs of life at all. Power button did nothing. Remote did nothing.
                                        Replaced PSU board: No improvement.
                                        Replaced main board: WORKED AGAIN. For a couple of weeks. Then failed again. Same symptoms.
                                        Is it possible something in my TV is killing the main boards? Or do the main boards have a common failure mode and I just hit it twice?
                                        • tuner2000i
                                          Philips 65PUS8518/12 distorted image after main board replacement
                                          by tuner2000i
                                          hello everyone,
                                          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                          07-15-2025, 01:15 PM
                                        • ermals
                                          Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                          by ermals
                                          Hi all!
                                          I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                          1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                          2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                          3. I've checked voltages...
                                          08-01-2022, 10:35 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • silikon77
                                          Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
                                          by silikon77
                                          Hi!
                                          Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
                                          Found some advices watching youtube nad came up with this:
                                          It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
                                          I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
                                          See attached picture.
                                          I tried a few combinations to block individual clock...
                                          01-02-2025, 02:26 PM
