Just picked up a 55 inch LG 4k OLED for $50!
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Just picked up a 55 inch LG 4k OLED for $50!
    I shloukd have noticed this before but the outer ribbon to that area in question on the panel has a solid burn through a trace on the ribbon. Obviously a short. I swapped cables from the opposite side to hear a subtle ticking sound from the tcon. Most likely the end COF is melted.
    • Davi.p
      • Sep 2009
      • 4270
      • Italy - Milan
      What do you mean for short? 0v in diode mode? 0ohm?
      • Davi.p
        • Sep 2009
        • 4270
        • Italy - Milan
        "Most likely the end COF is melted." Don't judge an object that you don't know, i guess you never dismounted a OLED panel, there can be more electronics on that than lcd panels, surely you have to remove that funny "carpet" around the thing.. (i mean that strange white texture )
        • Davi.p
          • Sep 2009
          • 4270
          • Italy - Milan
          But on the tcon there's a product. date, is 2015 or 2012? Is there any SM?
          • freakaftr8
            • Oct 2012
            • 3743
            I will investigate further however I don't know how to pull off this back cover
            • freakaftr8
              • Oct 2012
              • 3743
              Ok. Believe it or not I scored a NOS panel from ebay!! Before I replace the panel I am going to check different capacitance readings between the 2 panels and see if I can straighten this 1 out 1st but somehow I managed to find one out of Utah for 300 bucks unbelievable!
              • freakaftr8
                • Oct 2012
                • 3743
                Got the panel. The readings on those 4 caps on the panel that were 80 ohms are 250 ohms on this panel. Same as other side. However I still have a mainboard issue.
                Nothing while pressing power button. Pressi g power on remote yields a flashing power LED. That's it
                Only 3.5v to mainboard. Nothing being sent out.
                Can manipulate panel on, power on, and 12v,24v on with resistors. New panel lights up.
                No 3.3 to VCC of eeprom. As a matter of fact, no 3.5 or 3.3 missing in a lot of areas.
                Nothing on voltage regulators, nothing getting even slightly warm, even after forcing ps_on
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Btw I don't get test patterns with LVDS disconnected. Not sure but guess this tcon doesn't support that? Panel came with tcon.
                  Pretty sure on old panel/tcon it was attempting to initiate test patterns.
                  • Davi.p
                    • Sep 2009
                    • 4270
                    • Italy - Milan
                    #29
                    "New panel lights up" with which image?
                    "No 3.3 to VCC of eeprom" which eeprom? marking?
                    "no 3.5 or 3.3 missing in a lot of areas." ???? Are you forgeting a comma?
                    "Nothing on voltage regulators" Are you meaning only single chip linear or dc-dc switching p.supplies?
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      When I say new panel lights up it esentially primes where you can see the pixels illuminate with a very dark glow.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        There is no VCC to any pens on any of the voltage regulators or Eeproms. Even when I force power supply on I get 12 V and 24 V all over the board but yet nothing going into any of the voltage regulators or eeprom. I have searched all areas of the board for fuses and inductors and they all test good so I'm starting to think that there is something else going on here
                        • Davi.p
                          • Sep 2009
                          • 4270
                          • Italy - Milan
                          #32
                          Is not very useful to test an inductor, i've never found or hear one defective, also testing dc-dc regulators seems not useful 'cause your problem is to start the tv, maybe the standby processor is embedded in the main cpu and uses an external flash spi to run the sw. Check if there's that flash and if is powered, usually it has a paint mark on it. Given that the standby led is lighted, the cpu is working but maybe it needs a special procedure to fault reset or has no good sw on the spi.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            That's what I'm figuring it does use an external Flash eeprom. I believe there some reset procedure as the guy I bought it from said it will only turn on so many attemps with a bad panel until it goes into this procedure or mode.
                            Uses a Macronix M25Q032A. Already tried resetting by ground to reset pin 7. However there is no VCC to the eeprom so efforts are pointless.
                            • Davi.p
                              • Sep 2009
                              • 4270
                              • Italy - Milan
                              #34
                              "Uses a Macronix M25Q032A. Already tried resetting by ground to reset pin 7."
                              What is this reset?? Are you trying to erase the standby software? Why??
                              "I believe there some reset procedure as the guy I bought it from said it will only turn on so many attemps with a bad panel until it goes into this procedure or mode. "
                              Sorry i can't translate...
                              Anyway aren't you able to follow a bit the path of the 3,5v in input to where it stops?
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Yes I followed it in to the main processor and the NV ram modules but nothing coming out to Eeprom
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  #36
                                  Im curious if you can fix this tv. How much did you pay for the panel?
                                  I thought most OLED's fail with either the panel or T-con and not mainboard? No way to download some firmware somewhere?
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    I paid 330 with shipping. Yes OLED seems to be very problematic as the chip on film ribbons get extremely hot. This one inevitably appears to be a mainboard failure as I can apply resistors to the circuit to power up the 24, 12 V and get the tcon up and running and give me a blank black raster. I did that with the other panel and was presented with a huge vertical stripe on the right side. I have still yet to dismantle that panel however there's a gentleman here in Sacramento that has ATV same model with a cracked screen for $80 that I'm gonna pick up. Maybe get a good main board out of that one and look for the differences between the boards to find out what's wrong with this mainboard.
                                    Even though main board failures seem to be rare and OLED, It's still in LG and LG is infamous for failed BGA on main processor.
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      I think when I get it all repaired and up and running I'm going to turn around and resell it. I will take LED backlight failures or 1080p plasma over burning OLED panels anyway of the week.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #39
                                        whats the full model number of this set.
                                        • freakaftr8
                                          • Oct 2012
                                          • 3743
                                          55eg9600ua
                                          • djordje
                                            Philips 55 oled 804/12 red light blink
                                            by djordje
                                            Hello all,
                                            I have Philips Oled 55 (804/12) with black screen and red light blink.
                                            I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                            Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                            When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                            My questions is what should i do next...
                                            01-03-2025, 04:00 PM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:40 AM
