Just picked up a 55 inch LG 4k OLED for $50!
    Re: Just picked up a 55 inch LG 4k OLED for $50!
    doubt you can fix OLED image retention, it will be permanent.
    • freakaftr8
      • Oct 2012
      • 3743
      Yea. And it's bad. Some ahole used it as a computer monitor downloading bit torrents.
      • mmartell
        • Oct 2013
        • 3189
        This is a supposed "new" panel ? And with a blown tcon attached to it ?
          Great works!
          May be you should also upload the WAV file you use also.
            I don't know who would buy an OLED, a 4k one at that, and then proceed to use it as a computer monitor. Some people are just idiots apparently
            • freakaftr8
              • Oct 2012
              • 3743
              Right!!?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4462
                • Italy - Milan
                #167
                Freak you better claim your money back, this screen is useless, it's incredible how many dishonests in internet there are...
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Indeed! Take a look!! Whom ever bought this and used it as a computer monitor obviously had money to play with. These are the kind of people that say, " If I wanted to go camping I would have stayed at a 4 star hotel"!!
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    OK this gets even better!! after the TV's been on for 4 hours LG OLEDS go through what's called a compensation cycle. Has anyone heard of this before? Basically it does a cleaning process internally against the organic LED compounds and Clears the pixels somehow through a series of voltage buffers. Something like that I'm not sure however I let it sit for its 10 minutes and I turned it back on everything that I saw that look like burn in is gone !!
                    the picture is crystal clear!! Not one ounce of burning or image retention whatsoever!!
                    This clearly looked like severe burn in!! It's gone!!
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Here is the .RAR file containing the 3 wav files and instructions how to build the IR.
                        the fuck?
                        That's incredible.
                        I'd seen plenty of OLEDs with burn in - perhaps they just haven't been through their compensation cycle....
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4462
                          • Italy - Milan
                          #172
                          Bravo! Bis!
                            When you say OLED with burn-in (image retention), how can that be possible since the LED is either on or off unless the driver circuit is stuck on, I do not understand how to have image retention with OLED. Where can I learn more about that symptom and the explanation?
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              I know Right! Here are some better pictures depicting the grayscale areas that were the worst. I just turned it on this morning and it does not look like the same panel that I was looking at last night. It's amazing!
                              I might just keep this one.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                OLED still uses TFT active matrix. The organic compound behind the active matrix TFT does the lighting. I saw screen burn I saw colors burned into the screen as well.
                                This cannot be possible with white film organic compound that is only on or off. So maybe quite possibly this was image retention that the panel subdued by itself electronically.
                                Of course this is only my theory I guess
                                  Difference between LCD and OLED.
                                  I am guessing the image sticking forms on the TFT1 device due to the storage capacitor Cs.
                                  An LCD uses ac bias, so the net charge across the storage capacitor is always nulled.
                                  I'd love to see an OLED based upon a plasma-panel style subfield drive mechanism, which would simplify the TFT matrix (no longer directly required) but I suspect would require extremely efficient OLED pixels to get high brightness.
                                    So it is the TFT (driver), not the actual Light Emitting Device (OLED), that causes the retention.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4462
                                      • Italy - Milan
                                      #178
                                      In Italian Wikipeidia i've seen those with double FET are AMOLED, used only in small displays..
                                      Why? It is not designed to discharge enough fast for the high freq. refresh cycles?
                                      I wanted to add that even LCD when has some problems at the screen / TCON has a sticky image sometimes, with my Sony for ex. i left disconnected one half screen and that half showed the previous image's phantom, and the tv was also switched off-on..
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        Indeed. Also I don't think they can produce plasma subfield upon oled dur to the fact that oled is going flexabe.
                                        Now that presents another conundrum if this technology is so finicky and dangerous like if it gets punctured, If it stays alive wont it act somewhat like a lithium ion battery when punctured?
                                        I only ask because now on to the bad panel..
                                        When I was scoping the current draw between the good panel and the bad one, the Vertical lines on the right hand side I noticed that there is a significant current draw at the 1.8v. Is this not VCC? These are the capacitors. I posted the picture earlier Of the capacitors on That I noticed were darker. That section is reading 84ohms. On the good panel it reads 250ohms. I removed those capacitors and I get 50 ohms. I put them back because the good side measured 84 ohms also. Whatever I replace or remove on the bad side changes the reading on the good side also. I'm confused. They must be linked together inside the panel somehow as the board on the right is separate from the left. The right farthest COF driver is obviously shorted. If I remove 12 V to tcon, The TV will state powered. And soon as I Introduce the 12 V back, The TV does something odd I can see a horizontal line withiin the vertical lines scroll from top to bottom of the.panel. As soon as that line reaches the bottom the TV shuts down. With the capacitors removed and the TV only reading 50 Ω on that section, When I power up the TV it immediately shuts off without displaying anything. With the capacitors in place and the 84 Ω reading the TV will stay powered up until this scroll line reaches the bottom of the panel.
                                        I know this all sounds confusing but this is what I am seeing.
                                          That's wrong, all large and colour OLED panels are AMOLED.
                                          Only very small panels are PMOLED (Passive-matrix OLED). Example, the small screens found on smart watches/Fitbits. These panels suffer uniformity issues when driven with bright content, and so are not presently suitable for OLED TVs. This might change in the future, though.
                                          This would be because the T-con generates the ac-bias control signals, no t-con connection no ac-bias. This can cause permanent damage to the panel, but it is usually reversible.
                                          • djordje
                                            Philips 55 oled 804/12 red light blink
                                            by djordje
                                            Hello all,
                                            I have Philips Oled 55 (804/12) with black screen and red light blink.
                                            I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                            Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                            When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                            My questions is what should i do next...
                                            01-03-2025, 04:00 PM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:40 AM
