Just picked up a 55 inch LG 4k OLED for $50!
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Just picked up a 55 inch LG 4k OLED for $50!
    Originally posted by budwich
    not sure I would lay the blame on firmware especially since you indicated that you "swapped the guts" of two tv's. That sounds rather unusual.
    Yes but both TV's suffered from some kind of damage to the O LED panel. Being either by short or crack. In turn this disables in locks out some portion of the main board. Both of my boards had suffered this symptom. People on the other forums including the guy I bought the original TV from said that it would try to power on he would see the Web OS show up on the screen and then it would restart 5 times after the 5th time you get locked out. He mentioned that the LG representative was using some kind of dongle to reset the board.
    • budwich
      • Jul 2015
      • 3097
      yes but the "issue" discussed was about a "firmware issue", what you are indicating is more of "normal operations of failure protection design" by LG.
      Anyways, the reset sounds "similar" to those that use a "soft method" (with keys and power plug)... just more labor intensive. I would still check out the regulator conditions to understand what is happening around that area since you see nothing in those voltages.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4462
        • Italy - Milan
        #103
        However the Micom has a firmware area and a RAM, i don't know if an MCU (the micom) is able to flash itself partially to write this phantomatic flag...
        have you tried to keep pushed the reset button while you power on the tv or when you give AC power to the tv? that button will have a function or not??
        At the page 47 there's another button SW1901 that active signal URSA_RESET_MICOM that goes into the micom..
          Are you sure it even has a way to detect the OLED panel is bad?
          I say this because it doesn't seem to have a feedback pin on the power connector?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4462
            • Italy - Milan
            #105
            The micom always communicate with main cpu, and as usual cpu communicate with TCON through a serial i2c line..
            • freakaftr8
              • Oct 2012
              • 3743
              I have not quite tried that particular sequence however this is on the 55EG9600-UB mainboard. The 55EG9600-UA doesn't have a SW3000 there. All though I took the end of a flathead screwdriver And was able to shut down and reset the MICOM as well but it did not make any difference since the solder joints are there, just no switch. That board also is receiving 3.5v to IC3000, And is putting out a 3.5v to RL-ON
              SW1901 is dead. No V in no V out essentially does not do anything, ive tried.
              • budwich
                • Jul 2015
                • 3097
                you say there is no 5v in the set. Are you saying that you never see it or that there is no points for 5v... even the usb port?
                • freakaftr8
                  • Oct 2012
                  • 3743
                  There is standby 3.5v. It comes in and obviously is operating the MICOM, Which in turn operates the IR/power button/LED indicator. But it doesn't seem to be sending anything in the ways of output. Everything else on thw board is totally and completely dead.
                  The power supply is doing it's job it is sending 3.5v standby I can jump PS on to 3.5, DRV on and 12 on and my 24v and 12 V and all the rails come up the panel comes up. But yet the main board is still completely dead so it's not doing anything and just by passing it on the front end to see if the power supply, tcon ann the panel is operating
                  • budwich
                    • Jul 2015
                    • 3097
                    You need to check the 5v regulator to see what conditions are there as based on my read, everything starts with it getting going.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      True, however ot appears that from 3.5v input to mainboard, the tract immediately goes to IC3000. I cvould be wrong, but if true, IC3000 is defective or erased, causing the rest of the circuits to be dead.
                      • budwich
                        • Jul 2015
                        • 3097
                        ??? I am not sure how to read your statement. I think you are trying to say that the 3.5v input is used to do something. I am not talking about the 3.5v "supply", I am talking about the 5v "supply". It has its own regulator and it comes from 12v. Again, you are wise to look at the conditions around the regulators to see if they are present as it is quite possibly since you are dealing with "failed set harvesting" that a likely issue may be a bad / failed regulator as opposed to anything else.... at least until you can confirm that the regulators have the proper conditions to operate correctly.
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          I've just confirmed if I ground out pin 36 on ic3000 for RL-ON, the power suppply comes live. Still no response or boot. At least that confirms the signal from that IC is getting to the power supply.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            budwich, you are correct on that, however the 12v doesn't come up unless RL-ON is triggered. It can't even get to that point if it's not loading the firmware packet
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              #114
                              Isnt there a way to get into some kind of service menu and deactivate the "lock"?
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4462
                                • Italy - Milan
                                #115
                                Fu**ing Koreans doesn't pubblish the SRV MEnu entrance method, but usually on LG sets there is a .Wav file that can be played with a pc or tablet and an IR led connected to the audio out jack, search the forum or web for this. And also i hate that stupid Chinese-english that they use!!!
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  OK.. but then I think you haven't set those conditions up correctly for it to happen... maybe. I haven't seen where you have checked / tried that. You have tried a few "stimuli" but I am not sure you have checked the result other than looking for voltage.... there are other status lines that should also show up somewhere.
                                  Actually, I am not even sure what panel you are actually working on since, it isn't in your title or the first post. :-) maybe I will just be quiet. I doubt an oled will be any of my future learnings... :-)
                                  OOPs... I see your model in the second post...
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Interesting read from someone else that had an issue with this set over on AVS.
                                    According to this guy apparently even replacing the main did not straighten the problem out even for a second when it had a failed panel.
                                    But I2C serial communications don't come up at all Even if the tcon board was reporting a problem with the panel the main board doesn't have any voltages to register this.
                                    Funny how the guy mention that LG is going to show up with a USB boot and load. And also two main boards and no even attempt to power up
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Judging by what I'm reading, nothing fixes this issue. Even when an LG tech comes to your home and replaces every board, (twice) and even the panel.. wtf?
                                      • Moreno83
                                        • Jun 2014
                                        • 2008
                                        • The Netherlands
                                        #119
                                        Isnt there a company where you can buy a OLED and test it first for a few days and return it if you dont like it? Remove the back cover of the new tv and copy the data from the EEPROM to a USB haha
                                        I would think the panel is somehow registered to the mainboard and swapping mainboards wont help.
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4462
                                          • Italy - Milan
                                          #120
                                          Moreno you would be happy if you buy a tv that someone already got into and mess with?
                                          Freak i don't find any technical discussion on that forum, only purchase advices, where is your discussion?
                                          How a mainboard would refuse to work with a different panel, you don't have changed only the panel and not the tcon? digital electronics are on the tcon not on the panel.
                                          • djordje
                                            Philips 55 oled 804/12 red light blink
                                            by djordje
                                            Hello all,
                                            I have Philips Oled 55 (804/12) with black screen and red light blink.
                                            I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                            Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                            When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                            My questions is what should i do next...
                                            01-03-2025, 04:00 PM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:40 AM
