Just picked up a 55 inch LG 4k OLED for $50!
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Just picked up a 55 inch LG 4k OLED for $50!
    The ATML eeprom is on this board. This looks promising except I'm not getting VCC so this would essentially be pointless. Obviously it's not reading eeprom.
    Courtesy of Samygo
      Btw for those wondering.
      OLED is very similar to LCD.
      It uses a TFT, each pixel consists of a transistor which regulates current through an OLED pixel. The organic emissive layer makes light when current flows through it... somehow... I'm not clear on this bit.
      I believe the TFTs are still driven by gate and source drivers and the OLED pixels are connected to the drain of these devices, likely from the +24V supply.
      I am not sure what, if any, power is dissipated in the COFs - I suspect it will not be much more than an LCD - though the panel will get warmer...
      • freakaftr8
        • Oct 2012
        • 3743
        The panel gets quite warm right on the bottom all the way across. Almost hot to the touch. I have verified this on a few demo televisions at our local Best Buy
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4461
          • Italy - Milan
          #64
          I dont want to make so fantasy suppositions, i dont have seen schematics nor complete images of the board but if there is a parallel flash and a serial one i guess the serial one holds the standby softw. and a cpu can't go in to protection without executing a routine, if the ser.eprom is not getting power then no code executed, maybe you can buy a cheap eeprom programmer like ch341 on ebay and try to read the content of the ser.flash and see if it's good or a crust...
          • freakaftr8
            • Oct 2012
            • 3743
            Actually I have arduino. May be able to program with it. Never tried yet. It has usb capability.
            • freakaftr8
              • Oct 2012
              • 3743
              But the serial eeprom should be powered to recognize firmware or execute commands.. This one is not. And yes there appears to be two eeproms. Maybe backfeed VCC at front end of eeprom??
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4461
                • Italy - Milan
                #67
                Freak please be clear, flash memory are on thing (them stores firmwares) and eeproms are another (stores settings), i've never used an Arduino, ch341 are very very cheap, and if you repair tv you better get one or better a more powerful cheap programmer like TL866 or RT809F or others.. i was just say that, you say that mainboard gone into protection, but how can a st.by processor see the problems if it doesn't execute code? Why and how a processor exclude vcc to a serial flash? Anyway i'm wondering if a programmer could be useful, if the flash eprom is not powered then a processor can't execute code and so the content could be intact. Is there a schematic in the SM you uploaded?
                "Maybe backfeed VCC at front end of eeprom??" Sorry i can't translate..
                • freakaftr8
                  • Oct 2012
                  • 3743
                  OK here are some pictures of the main board with the heat sync removed.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    IC402 seems to be eeprom. IC9101 is serial data possibly? Anyway none of these are getting VCC
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4461
                      • Italy - Milan
                      #70
                      I don't see well the marking on the chips, you make faster if you transcript here all the markings on the 8 pins ics, even that shrinked types..
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        These two.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4461
                          • Italy - Milan
                          #72
                          ATML is a eeprom, 25L33 is a flash, are there any other? Have you tested any pins of the flash for the vcc? Is the vcc pin of it connected to a fuse?
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Yes i cjecked vcc ot both. And I haven't seen any fuses.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              The other guy settled on 60 bucks. He is bringing the broken OLED to my house right now.
                              So maybe if I figured this one out I can somehow get the other panel figured out somewhat, And in turn Put the guts from his TV on to the other panel that I removed from mine..
                              In turn I'm going to strip the cracked busted panel out of that one and take plenty of pictures of the ribbon drivers and Chip on film and driver boards that run the OLED panel since its rubbish anyway.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Got the damaged one. Can somebody say oopsie. Shipping damage?
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Yes folks, it does have side gate drivers.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    And here you have it! A look at the workings of an OLED panel.
                                    Strikingly similar to LCD except the organic compound on the back side of the panel. Mated to the LCD.
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      The panel is for certain not designed to remove If you have to access the driver boards. It will crack. Believe it or not the whole thing is held in by double sided sticky tape in 8 areas.
                                      I found the LCD layer to be extremely fragile like typical LCD's but the organic LED or OLED layer behind the LCD was super flexible
                                        It's a TFT layer...not quite the same as an LCD.
                                        Interesting that the ELVDD power passes through the source drivers, and disappointing... is that the only supply path for ELVDD? (The 24V supply from the PSU, which supplies the current for the OLED pixels).
                                        Also interesting that the pin-out of the drivers is similar to PDP address drivers, something LG would have had experience with. Unlike normal source drivers, there's a high-power path for OLED current. I was hoping that it would be supplied directly to the panel via a pair of dedicated pads.
                                          IC8100 is your eMMC device which holds the TV's operating system. It's a Toshiba part so bets would be that it's failed. They were notoriously unreliable after few erase/write cycles when used by my former employer.
                                          IC1901 is probably for the FRC controller, which is some kind of advanced DSP. May also be a problem.
                                          • djordje
                                            Philips 55 oled 804/12 red light blink
                                            by djordje
                                            Hello all,
                                            I have Philips Oled 55 (804/12) with black screen and red light blink.
                                            I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                            Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                            When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                            My questions is what should i do next...
                                            01-03-2025, 04:00 PM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:40 AM
