Samsung UN46ES6150F starts power cycling after 2 hours of use from a cold start
  • triplefour
    • May 2014
    • 1747
    Re: Samsung UN46ES6150F starts power cycling after 2 hours of use from a cold start
    ok i was able to clean the IC with 90% isopropyl, a bit of toilet paper and some elbow grease.
    IC9101 markings:
    SLC2012M
    D3385BGP
    i can find it on ebay
    https://www.ebay.com/itm/SLC2012M-Pa...QAAOSwi4lae~ay
    but i cant seem to find the datasheet
    i find a datasheet for SLC2012 but it doesnt seem right and doesnt tell much
    Don't fear the repair...
      This is the schematic of how SLC2012M is used in Samsung TV. i M NOT 100% sure how accurate the SCH is.
      • triplefour
        • May 2014
        • 1747
        thank you that is very close to my board which is BN44-00502A. how did you find this? and what does SCH mean?
          SCH = Schematic
          I found that a while back while searching for the 'SLC2012M schematic'.
          • tmlfan
            • Jun 2011
            • 109
            #45
            so i have been following this thread, i have the 46 inch version of this tv that seems to have the same issues, when i unplug the main board from the power board and plug the tv in the screen lights up but does not flicker, just stays lit up
            • triplefour
              • May 2014
              • 1747
              pretty much a definitive test showing that your PSU and Backlights are fine. your problem is most likely on the mainboard. try with mainboard connected, but TCON disconnected
              also i hate to admit it, but i bit the bullet and bought a new PSU which fixed my problems. i wouldnt have done it but it was only like 25$
              i still want to fix the original PSU. i still have the tv, and am not going to sell it because i dont quite trust my backlight repair job, and during all that, i put a lot of smudges on the plastic sheets behind the panel, and you can see scratches, and spots of differing color, etc
              maybe one day ill take it apart and replace all those screens, and use the good PSU to help diagnose the bad one...
              • tmlfan
                • Jun 2011
                • 109
                #47
                with the psu and main connected to each other i unplugged the tcon and powered on tv, backlight stays on for 3-4 minutes then goes out, realizing i never left tv on that long when i tried backlights plugged in to psu only i went back and tried that and left pluged in for 10 mins or so and backlight stayed on the whole time, i assume this means that the problem is in the mainboard and not the tcon or psu
                • triplefour
                  • May 2014
                  • 1747
                  99% sure you've narrowed it to the mainboard. just to confirm what does the tv do when all boards are connected normally?
                  • tmlfan
                    • Jun 2011
                    • 109
                    #49
                    runs for hr or so then starts to randomly reboot, pretty much same thing yours was doing
                    • triplefour
                      • May 2014
                      • 1747
                      yes but in my case, it was the PSU that was at fault... try run with just psu and backlights for an hour just to be sure it doesnt start cycling
                        09-07-2024, 05:50 AM
                      • high-tech
                        Samsung UN55F7050AFXZA ver. TD01 power cycling
                        by high-tech
                        Hello everybody, I could use some help on this one... It's got me guessing...
                        I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                        (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                        (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                        (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                        (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                        9. ground (PWM2) 10. 0.9 volts cycling...
                        09-15-2020, 03:39 PM
                      • JohnML1975
                        LG 49UK7550PTA - after couple of hours screen starts to blink
                        by JohnML1975
                        Hello Forum team
                        Have this TV; searched for the model and could not anything so thought I would share in here
                        Had an issue, some years ago, and looks like some placed sticky tape over some of the lines on the FFC cables between the T con and the mainboard
                        Anyway, the owner, who gave me the TV, says it starts to blink after a few hours
                        So I removed the covers, and could not see anything visibly
                        Removed the power supply and thought some of the solder joints, on the hot side, were not the best. I thought some looked like they were cracked.
                        07-25-2025, 10:48 PM
                        09-06-2024, 11:40 PM
