Sony KDL-40EX520 Switches off after 2 secs
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Hi everybody,
    I have two identical Sony KDL-40EX520's, both have faulty main cpu pcb's
    I have one good working main cpu pcb, which gets both sets running perfectly.
    The faulty main cpu pcb causes both sets to run for two seconds, and then power down with a red led.
    You then can't power the set on without disrupting the mains.
    I see in the factory settings listing that to enter the factory setting on Sony's, you have to "arrow up on the remote, and power on button on the set (set on)." On time interval not long enough to reset.
    I don't have a Eeprom flash programmer.
    I tried shorting pins 5 & 6 on the only eeprom I could see with obviously no result.
    Any suggestions?
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Re: Sony KDL-40EX520 Switches off after 2 secs
    I guess its off to the agents.....
      ALL the fuses on the FUSES on the main board OK?
      https://www.badcaps.net/forum/attach...4&d=1512559410
      I see 4 fuses on the top side of the board, there may be more on the bottom side of the board too.
      Did you do any Voltage testing comparison between the working board and the non-working boards?
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • cheeky2
        Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
        by cheeky2
        For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
        See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
        01-08-2024, 05:56 AM
      • joby91
        SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
        by joby91
        I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
        I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
        I found one chat about firmware on ************** forum but i cannot read the comments.
        https://**************/forum/108-114100-1#880537
        09-04-2024, 01:34 PM
      • cheeky2
        by cheeky2
        05-25-2024, 03:27 AM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
