Intermittent malfunction lg 47lg70
  • MPell33
    • Dec 2017
    • Miami Dade
    Hello
    I have a question. Before ordering a new t-con and possibly destroying my tv by taking it apart to replace it I need to know one thing. Is it the t-con? Or maybe loose cables? Or anything else.
    This is what happens. One day it's working perfect. Then half way through the day or another day or even weeks later it goes nuts. The black color stops working. Anything black on the tv has purple lines. Then another day it's working fine again.
    Anyone know what it is? Or could be?
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Intermittent malfunction lg 47lg70
    Could be a loose lvds cable Or more famously one of LGs famous BGA soldering connections on the main processor on mainboard.
      Any screen shot to show us exactly what it looks like on the screen?
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • netgearnetgear
        TCL 43S423 TCON OR PANEL FAULTY???
        by netgearnetgear
        Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
        08-20-2025, 06:04 PM
