LCD Pannel missing RED in every second pixel
  • Sojke
    • Apr 2017
    • 131
    • Serbia
    Hi guys. I have an LED panel LG LP140WD2 TL D2 which suffers from missing an RED part of the pixel for every second pixel over the entire screen. Example:
    [RGB][ GB][RGB][ GB][RGB][ GB]
    I doubt its the drivers , 3 of them, because than that would mean that all 3 failed at the same spot, which sounds less likely, I believe it is the controller (LG SW0646) or perhaps some passive components leading to or from the controller.
    Any one had any luck of fixing such an issue?
    Also , are there any actual LCD electronics repair resources anywhere??
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LCD Pannel missing RED in every second pixel
    Reseat lvds cable? Also I would try cleaning the pin connections on the cable first
    • gabiz_ro
      • Mar 2011
      • 171
      Don't think cable result in such effect.
      RGB are wide spread in LVDS signal format,and since only R are missing no imperfect contact have such behaviour to occur only on right timming to affect only Red.
      Panel datasheet
      http://www.datasheetspdf.com/pdf/908...P140WD2-TLD2/1
      You may test with other display (no matter size,only compatible pinout,most are standard 40 pin connector) )and see if defect persist then is from laptop if defect gone then problem is in display.
      • ugamazing
        820-02020 PPBUS_AON missing
        by ugamazing
        Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
        Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
        02-05-2025, 04:21 PM
      • jpreza
        Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
        by jpreza
        I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
        Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
        It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
        Looking at the card, it appears to be missing the following:
        1x 1.0uH inductor - orange square
        2x...
        11-01-2024, 10:54 PM
      • BYTEHAT248
        Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
        by BYTEHAT248
        Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
        11-14-2025, 04:48 PM
      • gurj1979
        Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
        by gurj1979
        Hey guys.
        Need help with this one.
        Fan not spinning due to missing PWN Fan signal.
        Also 5 seconds from powering up it freezes, unless in BIOS.
        But as soon as Windows starts to load, it will freeze.
        CPU is COLD / Room temp when it freezes.
        I've replaced the CPU, same problem.
        Replaced SIO/KBC IT8987e and reprogrammed - same problem.
        Replaced fan - same problem.
        Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
        Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
        08-19-2024, 05:22 PM
      • salopian
        Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
        by salopian
        Hello. I would need some advice please.
        My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
        He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
        I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
        I have already replaced the logic board with another...
        02-27-2021, 07:30 AM
