Sony KDL-60EX700 dismantling problem
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4562
    • Italy - Milan
    I have bought this some days ago, screen fault, but i'm stuck on dismantling the screen bezel, if you have tried it with success can you tell me how? The higher side doesn't come away! It's a very heavy beast, and i'm lonely to handle it..
  • tn245
    • Oct 2013
    • 530
    Re: Sony KDL-60EX700 dismantling problem
    I took apart a bad panel 40EX720 to harvest led strips and I remember one edge of the bezel was actually glued down to the frame once all screws were removed. I just had to keep prying with a plastic spudger and the glue came away bit by bit. I don't envy you with a 60" trying not break the panel. Good luck!
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4562
      • Italy - Milan
      Thanks very much, you surely been precious, i will try and report back, now i have many televisors to fix so i jump from one to another. Bye!
      • Chrissygizmo
        Sony KD-55XG9505 lines on screen problem
        by Chrissygizmo
        Hello again everyone,
        This is my latest mission, to try getting this Sony tv back to normal working order…
        I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
        02-19-2025, 11:31 AM
      • crackedprint
        Sony HCD-HX80R Amplifier Volume Control Problem
        by crackedprint
        I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
        I have tried a Cold Reset as per the service manual.
        I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
        I have looked all the way through the service manual and tried many online...
        01-21-2025, 12:18 PM
      • retrorepair
        SONY KDL-40P3600 Picture Problem
        by retrorepair
        Hello gurus, hope you can assist me...
        I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
        I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
        Thanks in advance.
        10-11-2024, 05:12 PM
      • guruji
        Sony mbx-266 problem
        by guruji
        Hello
        I this Sony mbx-266 it powers
        on all the voltages are normal the strange part iOS the caps key num key works which shows the machine has booted but no video at all internal dp and the ext vga or hdmi.I have changed the bios but same issue. What do I check ??
        07-25-2025, 08:10 AM
      • YasaCh
        sony kd-49xf9005 4 red blinking problem
        by YasaCh
        Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
        05-05-2025, 08:40 AM
