Samsung Le40a456c2d previous image stuck on screen
  • sordids999
    • May 2013
    • 2161
    hi guys
    just need to confirm if this Tcon board is faulty
    T400XW01 V5 40T01-C00
    VGamma 1 6.86V
    VGamma 6 7.28V
    VGamma 9 7.37V
    VGamma 10 7.55V
    VGamma 11 7.57V
    VGamma 12 6.63V
    VGamma 14 4.89V
    VGamma 17 4.16V
    VGamma 22 0.33V
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4542
    • Italy - Milan
    Re: Samsung Le40a456c2d previous image stuck on screen
    Why some gamma are missing?
    • CapLeaker
      Leaking Member
      • 8352
      and a picture of the screen. I wonder if the problem is on the whole screen, or just an affected area. Usually a faulty Gamma IC just friggs around with the color, solarization etc.
      • sordids999
        • May 2013
        • 2161
        These are the only gamma voltages on the board I can find
        Image uploaded
        • sordids999
          • May 2013
          • 2161
          I was told the tv was losing colour and sometimes an image is stuck when the picture changes just like plasma burn in but at the moment I can't get the tv to show any faults
          • CapLeaker
            Leaking Member
            • 8352
            check all the pins around the AS15-F. Clean the ribbon cables going to and coming from the TCon.
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              also attach one ribbon from the t-con at a time and see if it has lag on 1 half only.
              more gamma readings would of been handy. who designs these boards, :P
              but your vgamma 1 is out of sequence, so you may still have an as chip issue.
              WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
              • snowfun
                • Aug 2012
                • 21
                • Portugal
                Have you changed already? AS-15 ? if not change it,many problems with gama with as15.
                • noledud
                  • Dec 2013
                  • 413
                  • united kingdom
                  picture of the fault would be better but no fault no fix
                  the few voltages you have given dont look right noting the number 1 value
                  there are repair services for the AS15 gamma chip on ebay if you dont fancy doing it your self
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4542
                    • Italy - Milan
                    "check all the pins around the AS15-F" it's risky to measure directly on the chip..
                    the missing gamma testpoints can be on the bottom side..
                    • saddle_au
                      Waste Warrior
                      • 121
                      Check the negative voltage generator on the TCON.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        If you cannot/don't have tools and skill to change the AS15 Chip on the T-CON Bd. You could probably get one on-line for a reasonable price. Replace the T-CON Bd.
                        • sordids999
                          • May 2013
                          • 2161
                          update ## As15 chip replaced
                          Tv all working again luckily spotted some solarization and brightness issues so changed the chip
                            09-07-2024, 05:50 AM
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 06:20 PM
