Samsung Le40a456c2d previous image stuck on screen
  • sordids999
    • May 2013
    • 2158
    hi guys
    just need to confirm if this Tcon board is faulty
    T400XW01 V5 40T01-C00
    VGamma 1 6.86V
    VGamma 6 7.28V
    VGamma 9 7.37V
    VGamma 10 7.55V
    VGamma 11 7.57V
    VGamma 12 6.63V
    VGamma 14 4.89V
    VGamma 17 4.16V
    VGamma 22 0.33V
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4452
    • Italy - Milan
    Re: Samsung Le40a456c2d previous image stuck on screen
    Why some gamma are missing?
    • CapLeaker
      Leaking Member
      • 8324
      and a picture of the screen. I wonder if the problem is on the whole screen, or just an affected area. Usually a faulty Gamma IC just friggs around with the color, solarization etc.
      • sordids999
        • May 2013
        • 2158
        These are the only gamma voltages on the board I can find
        Image uploaded
        • sordids999
          • May 2013
          • 2158
          I was told the tv was losing colour and sometimes an image is stuck when the picture changes just like plasma burn in but at the moment I can't get the tv to show any faults
          • CapLeaker
            Leaking Member
            • 8324
            check all the pins around the AS15-F. Clean the ribbon cables going to and coming from the TCon.
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              also attach one ribbon from the t-con at a time and see if it has lag on 1 half only.
              more gamma readings would of been handy. who designs these boards, :P
              but your vgamma 1 is out of sequence, so you may still have an as chip issue.
              WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
              • snowfun
                • Aug 2012
                • 21
                • Portugal
                Have you changed already? AS-15 ? if not change it,many problems with gama with as15.
                • noledud
                  • Dec 2013
                  • 413
                  • united kingdom
                  picture of the fault would be better but no fault no fix
                  the few voltages you have given dont look right noting the number 1 value
                  there are repair services for the AS15 gamma chip on ebay if you dont fancy doing it your self
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4452
                    • Italy - Milan
                    "check all the pins around the AS15-F" it's risky to measure directly on the chip..
                    the missing gamma testpoints can be on the bottom side..
                    • saddle_au
                      Waste Warrior
                      • 121
                      Check the negative voltage generator on the TCON.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        If you cannot/don't have tools and skill to change the AS15 Chip on the T-CON Bd. You could probably get one on-line for a reasonable price. Replace the T-CON Bd.
                        • sordids999
                          • May 2013
                          • 2158
                          update ## As15 chip replaced
                          Tv all working again luckily spotted some solarization and brightness issues so changed the chip
                            09-07-2024, 05:50 AM
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
                            09-06-2024, 06:20 PM
