Toshiba 46xv540ou
  • erj7
    • Nov 2017
    • 10
    Toshiba 46xv540ou
    First post!
    Problem: Startup and operation are fine until about 5-15 minutes. Screen goes black but power remains (audio cuts as well). Power cycling restores the video until about 5-15 minutes.
    I was told that I should look for bad capacitors on the power board. I've identified no obviously bad capacitors, but I would like people's help.
    Attached are some hi-res pictures I took of the power board, front and back.
    Thanks in advance
  • CapLeaker
    Leaking Member
    • 8179
    Re: Toshiba 46xv540ou
    We need high resolution, straight shot pictures of the boards.
    To me it sounds like you have a main board problem, not a PSU problem. On pic# 1 on the left there is this connector that goes to the main board. Turn the TV on and note down pin name and the DC voltage measured. Same thing again when the TV "acted up". Post that here.
    Just for reference: Only because a capacitor "looks" like new, it still can be bad. I just had a few examples of that last week. The best way to check the health of a capacitor is with an ESR meter.
    BTW: I think the model number of this TV is: 46xv540u
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      I encountered another TOSHIBA LED TV with similar issue that Model was a 55SL412U. The PSU was PK101V2510. I at first thought Main Bd. However while poking around I short cct something and toasted the PSU. I believe I was losing the 24V on the PSU. I bought a new PSU to start over the troubleshooting and to my surprise the TV worked and as far as I know is still working.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Also Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
        Format:
        Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
        1 - XXXXXXX - XXv - XXXv
        2 - XXXXXXX - XXXv - XXXv
        3 - XXXXXXX - XXXv - XXXv
        4 - etc.
        Also dcv across one of C1 main caps while tv is on
        • erj7
          • Nov 2017
          • 10
          Pin No. - Description (from Board) - DCV standby (V) - DCV On (V)
          1,2 - GND - 0.0000 - 0.0000
          3,4 - 12VA - 0.0300 - 11.842
          5-7 - GND - 0.0000 - 0.0000
          8,9 - 12VCC - 0.0300 - 11.842
          10-12 - 5VCC - 5.0000 - 5.0360
          13 - POWN - 0.0000 - 3.2975
          14 - ACD - 3.3620 - 3.361
          15 - DIM - 0.0082 - 0.2530
          16 - BLON - 0.0000 - 3.2851
          C1 while ON: 162.21V
            ":15 - DIM - 0.0082 - 0.2530" Recheck this dim control Voltage when the backlights are on, 0.25V is too low for the backlights to be on.
            • erj7
              • Nov 2017
              • 10
              Guys..
              First of all thanks for diving in. Secondly I think I may have shorted the power board after doing this...
              Before getting that reading, since the TV was upside down I went to check one of the C1 capacitors on the power board to see if the backlights were on. POP. The TV now refuses to turn. Some minimal burn on one of the C1 leads but the capacitor still holds 162DCV when plugged in.
              This just got more interesting. Where should I head to first so the TV can turn back on and we can get back to square one?
              Thanks in advance
              • dskall
                • Oct 2016
                • 2905
                • usa
                Recheck your voltages
                • CapLeaker
                  Leaking Member
                  • 8179
                  you have to fix the PSU first.
                  • erj7
                    • Nov 2017
                    • 10
                    Just a blown fuse.
                    The Dim pin reads .25 when the backlights are on. Any thoughts? Inverter circuit?
                    • CapLeaker
                      Leaking Member
                      • 8179
                      well... for shits and giggles, take the DIM pin off (so you don't backfeed), jump BLon to the DIM pin.
                      • erj7
                        • Nov 2017
                        • 10
                        Thanks, I'll do that tomorrow after work. I've talked to a couple techs at the company I work at (I took the TV in and plopped it in the lab), they've seen the problem and conclude it's probably a logic board issue. They say it's likely not worth the effort getting it fixed, just buy a new board.
                        Unfortunately, I'm having trouble finding a replacement logic board for the 46xv540u. The boards that I find do not physically match the layout that I see on the TV.. (example: https://www.ebay.com/itm/Toshiba-46X...IAAOSwcUBYJfhV)
                        Where's a good place I can look for replacement boards?
                        • jetadm123
                          • 2169
                          You can try shopjimmy.com
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                            09-06-2024, 05:27 AM
                          • atltechnology
                            Toshiba Satellite L50 PSKXWA-01100M Schematic Diagram Board View
                            by atltechnology
                            I need the Toshiba Satellite L50 PSKXWA-01100M
                            This is my board no : daobltmb8fo rev f
                            model no : Toshiba L50D-C
                            Part no : PSKXWA-01100M
                            Give me Schematic Diagram Board View
                            01-14-2025, 04:21 AM
