T-Con repair help
  • caphair
    • Nov 2011
    • 1249
    T-Con repair help
    32” LCD Tv has backlight but no display (sorry don't have tv in front of me for model number) but t-con seems to be the issue.
    F1 is open, I measure 12v from connector side and 0v from other side. F1 measures open as well.
    I tried powering tv on with my multimeter set to amps to bridge the fuse momentarily and see how much current flows so I could get an idea if the fuse happened to blow with no other issues, but when I do that the tv shuts off completely and needs to be unplugged for standby light to come back so I'm guessing if I replace F1 it would just blow again.
    I don't measure any shorts at the board side of F1. Should I try running 12v into it and see if anything heats up?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: T-Con repair help
    Did you try with cable disconnected from panel? What was your resistance measurement?
    • caphair
      • Nov 2011
      • 1249
      Did I try what with cable disconnected? Resistance of F1 is OL open
      • petehall347
        • Jan 2015
        • 4428
        you could try finding the short by checking from fuse to things like c21 c22 d2 etc .
        • dskall
          • Oct 2016
          • 2905
          • usa
          Did you try powering up with the panel disconnected from t-con?
          • caphair
            • Nov 2011
            • 1249
            No. Why what would this do?
            • caphair
              • Nov 2011
              • 1249
              I have and nothing measures shorted
              • petehall347
                • Jan 2015
                • 4428
                dskall is onto something .
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  You can then eliminate bad panel or board from t-con. Check the current draw across fuse with cable to panel disconnected.
                  • caphair
                    • Nov 2011
                    • 1249
                    Ok what am I looking for when doing this?
                    • NeedsMoreFlux
                      • Oct 2017
                      • 121
                      • California
                      I think what he is referring to is: disconnect one side of the ribbon cable and see if you get a picture on one side. Then try the other side.
                      If you are a noob show pictures and tell us where/what you tested, specifically.
                      You should see where the cables plug into connectors from one board to the other. there will be voltages listed. most times the t.v.s metal body can be used as ground.
                      Let us know...
                      Oh, and if you can't post pics: put them on your comp.
                      Right click, and select "edit."
                      It will open in Windows paint.
                      Select "Resize" on the top left.
                      Resize it to 2000x2000 pixels or lower, and make sure the picture is under 2MB.
                      Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
                      I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
                      Some of the things I've fixed:
                      60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
                      • caphair
                        • Nov 2011
                        • 1249
                        Let us know...
                        There’s only one cable per connector on the t-con (one from mainboard to t-con and one from t-con to panel) and the fuse F1 is open so how would I even try to get a picture through the t-con board?
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          Every t-con I've found with a shorted fuse, has just had the fuse replaced and the TV has then worked. If there's no short between the 12v and ground then replace the fuse and see what happens.
                          • caphair
                            • Nov 2011
                            • 1249
                            Ok but why when I used the meter in amps mode to act as a temporary bridge across the fuse the tv shuts down?
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              Perhaps there actually is a short in the tcon you've just not measured it correctly. If there is a short, bridging the fuse is a bad idea.
                              • caphair
                                • Nov 2011
                                • 1249
                                I tried running 12v through the tcon from the fuse end and only FL1 got hot but that just looks like a ferrite bead filter so it would just draw current with no resistance right?
                                Also noticed when injecting 12v the voltage dips down to 5v and full amps goes though
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  Sounds like a short.
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    Oh...Definitely a shorted T-CON Bd. The TV will shut down if it detects absent T-CON Bd as the fuse is open. This I found mostly with LG TVs.Re[place the T-CON Bd and your problem will be solved.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      Oh man, I did so many write-ups on T-con boards a while back, but it's going to take me a while to find those posts, so here goes a quick version of that.
                                      The T-con board for LCD TVs and monitors typically has 5 important voltage rails. These are:
                                      1) Main supply voltage: typically 3.3-12V that comes from the power supply and/or logic board. On your T-con, this voltage rail can be found at test point VCC (right by fuse F1).
                                      2) Main boost voltage: typically 12-15V, depending on the panel requirements. This rail is generated by a buck-boost converter from the main supply voltage rail mentioned above (VCC). On your T-con, this voltage rail can be found at test point VDD (below the 4 ceramic caps to the left of the top ribbon connector.)
                                      3) Secondary positive boost voltage: typically 15-30V. This rail is generated by a charge pump circuit from the main boosted voltage rail (VDD). On your T-con, this voltage rail can be found at test point VGH (above ceramic cap C54 to the left of the top ribbon connector.)
                                      4) Secondary NEGATIVE boost voltage: typically -5 to -10V. This rail is generated by a charge pump circuit from the main boosted voltage rail (VDD). On your T-con, this voltage rail can be found at test point VGL (right below the top ribbon connector.)
                                      5) LVDS chip VCC: typically either 1.8V, 2.5V, or 3.3V. It is generated from the main supply rail (VCC), usually by a linear regulator or two (like 1117 or similar). On your T-con, this voltage rail can be found at test point VCC2 (all the way to the right of the picture, next to that SOT-223 regulator with PCB designator "US2".)
                                      So the way I would attack this problem (blowing fuses on T-con board) is by first measuring the resistance from each of those test points above to ground. Anything with less than 100 Ohms resistance indicates a possible short-circuit, and anything with less than 50 Ohms (especially VDD, VGH, and VGL) is quite likely to be a shorted or partially-shorted ceramic cap.
                                      But for starters, post what resistances you get. Also, take two sets of measurements: one with the LCD panel cables connected, and one with those cables disconnected. As dskall tried suggesting above, we want to see if the panel is causing the short-circuit or not.
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        momaka I copied above post for future reference.
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • flibidy
                                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                          by flibidy
                                          I have here a Magnum IA.100 which belongs to my parents.
                                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                          What Ive done........
                                          01-01-2025, 01:26 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
