LG 37LH7000 no image, horizontal lines
  • mitsukiso
    • Sep 2017
    • 31
    • Италия
    i guess that it'a an easy question for you guys
    so the TV has no image but several thin horisontal lines (sorry for poor quality of picture). it doesn't show menu or change "image". sound ok
    i guess it's a T-Con board issue, just to be sure before buying one. Ribbons and cables are okay, tryed to clean them with rubber and alcohol. Thank you for help!
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 37LH7000 no image, horizontal lines
    T-CON Bds don't give horizontal lines when they fail. Your problem here is either a failing Main Bd of failed cables (Main Bd to T-CON Bd) Clean the cables with Isopropyl alcohol and make sure to re-seat them correctly.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4363
      • Italy - Milan
      Tcon must be tested at least power supply tensions. No one can play at Bingo with only a partial picture..
      • mitsukiso
        • Sep 2017
        • 31
        • Италия
        thanks for response! i have already cleaned the cables with no result. i'll try to replace them now.. hope it's not main board..
        • mitsukiso
          • Sep 2017
          • 31
          • Италия
          i'll try it now. Thank you for response
          • mitsukiso
            • Sep 2017
            • 31
            • Италия
            cables are ok, checked all pins. voltages arrive. found signs of overheating on the shield above the processor of t-con. quess i will try to change it
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4363
              • Italy - Milan
              Change the processor? Mmmh, i think rarely fails it..
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                The T-CON processor usually gets a little hot. I don't think that is your problem, though.
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
                • smartjohn
                  lg 60pz550-ua erratic horizontal pink lines over image
                  by smartjohn
                  Hello again old friends! I am perplexed with this set. The mainboard was reballed to fix the known issue of HDMI port loss. When it came back from service I reinstalled it and now have the attached image. The image is there but it looks to be some type of Z-sus problem. I have checked and rechecked and replaced the LVDT cable between the logic and main board with no luck. And yes, the inductors on both the Y-sus and z-sus have been re-soldered with clean new 60/40 material. All voltages match the panel label Vs=202, Va =55, Vzb = 110 (it was at 115 and was adjusted down) Vy = 180, and Vsc =150....
                  11-06-2022, 06:43 PM
                • shlomim412
                  samsung ua55es6800 - no image
                  by shlomim412
                  hi
                  having problem with samsung ua55es6800
                  tv had backlight on, sound working - responds to the remote control but no image.
                  check tcon board - had 12v in but no other voltages present.
                  when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                  when leaving only left side connected - again no voltages and no image.
                  put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                  kept trying to block less pins on the left ribbon cable...
                  05-15-2024, 05:00 AM
                • ggil44
                  Sony XBR-65X750D Horizontal lines bottom of screen
                  by ggil44
                  Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                  05-30-2023, 07:51 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
