Samsung PN64E533 Vertical green line and official no picture
  • geeforce
    • Oct 2017
    • 87
    After looking on here and YouTube... I'm going to run the voltage drop test, but it looks like the same symptoms of those failing blue capacitors (17 small ones on the y sustain board) for the blank screen.
    Saw a tampatec video with same green line solved by replacing the control board.
    Does this quick and dirty diagnosis seem somewhat correct? I've got an automotive multimeter I'm going to try and test with when I've got time. And I'll order the mini capacitors from Digi key on Monday.
  • geeforce
    • Oct 2017
    • 87
    Re: Samsung PN64E533 Vertical green line and official no picture
    Any quick thoughts?
    Cheers~!
    • geeforce
      • Oct 2017
      • 87
      Read that if I disconnect the panel ribbon cables from control board, if the lines go away, its possibly the control board, if they stay - its probably a panel failure .... Does that sound correct? Thanks
      • aaronwt6
        • Apr 2013
        • 855
        • US
        Looks like a panel failure to me.
        • rccrasher65
          • Mar 2014
          • 622
          Panel failure!
          • geeforce
            • Oct 2017
            • 87
            Thanks for input. Such a waste... Was free to me, but still feel bad scrapping it! All for a bad cof/panel fault. Wish we could somehow fix the error.
            Thanks again though guys!
            • cubytus
              Samsung UN50TU8000FXZC shows thin horizontal green line when warm
              by cubytus
              Hi to all,
              I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
              I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
              Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
              01-10-2024, 01:26 AM
            • otaku_nut
              Vizio E701i-A3 fixed but now has red vertical line
              by otaku_nut
              Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
              08-19-2025, 06:11 PM
            • hoot
              One vertical green line on my AQUOS LC-70LE740E TV
              by hoot
              on my AQUOS LC-70LE740E LCD TV there is a vertical green line on the screen. (pictures below)
              Does anyone know what the issue could be?
              Up close it looks something like this.
              Can this fault be serviced?
              What I want to do is the following:
              gently pressing on the ribbon connections along the top and bottom of the panel in the area of that line. Pushing a driver IC onto the flex cable it sits on to restore the lost connection. When the problematic area is found installing...
              11-21-2021, 07:48 AM
            • TrueSword88
              Kogan - KALED65XU9220STB - Blue Vertical Line
              by TrueSword88
              Hi all.
              I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
              The line just happens to coincide with the end of COF and start of the next COF (attached).
              The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
              Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
              Hoping to fix...
              05-05-2023, 04:28 PM
            • almarhum
              To fix laptop screen vertical line by working on its EDP cable
              by almarhum
              Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
              As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
              05-07-2024, 02:12 PM
