Samsung un60eh6003f horizontal lines
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Samsung un60eh6003f horizontal lines
    Originally posted by jb.
    hahahahahah hows that? geeze lighten up man...and no i am not an lcd expert,(its actually an led) but as others have said, its pretty clear in the picture....had i put a movie on, it would be harder to see then it would in contrast to the black background....clearly you are too ornary to help, so please move along
    It is still a LCD tv with led backlight instead of CCFL.
    Anyways back on topic.
    You need to figure out which side is causing the failure and remove all the tabs on that side.
    • budwich
      • Jul 2015
      • 3097
      your tv IS actually an LCD tv that is led lit... but the led lighting has little to do with your issue. Put a test pattern on the screen (lots to choose... color bars, etc)... this may help with identifying the areas that may be in trouble. Depending on the "pressure" that your putting on the frame, I would also check the connection between the bottom and side. Those cables might be "clampable" and you might "reseat" them accordingly.
      • jb.
        • Nov 2016
        • 33
        • canada
        i have figured out exactly which 2 tabs, directly across left and right from the lines in the picture...those tabs, just like the other side ones dont actually connect to anything, just hang off and had a little piece or tape on them...if i push the bezel in toward the glass (both sides at the same time) it goes away...
        no other pressure anwhere else has any effect, just those 2 side tabs
        and thanks very much for everyones help, much appreciated
        • jb.
          • Nov 2016
          • 33
          • canada
          what are those tabs for?(the ones on the side that dont connect to anything) you say to remove them?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4297
            • Italy - Milan
            "ORNARY"?! what slang is this? My language is not english.. write easy.. anyway you're a poor man and what you are here for? You don't even know the technology of your screen (you say led...) let's think if you can repair it... your TV hates you and it rebels to you with a panel fault, rightly... let it sleep on a landfill..
            • jb.
              • Nov 2016
              • 33
              • canada
              #26
              nah, im not tossing it because you are a grumpy ol man..one "lol" and you got bent out of shape..i asked you to move along, i love tearing things apart and fixing them, changed lots of boards on plasmas, and fix tablets and laptops....but new to this one....this forum is for people to come together and fix, but clearly you are a miserable person, please go away. thanks
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #27
                can you take some pictures of the tabs in question that connect to the lcd panel the ones you press and the picture goes good so we can see what were dealing with thanks
                • budwich
                  • Jul 2015
                  • 3097
                  there are tons of posts on this. You need to do as suggested and post a very good picture with a well known tv test pattern that people can easily recognize what is and isn't there. Then you can decide on further action like removing tabs.
                  • jb.
                    • Nov 2016
                    • 33
                    • canada
                    #29
                    sure i will do tonight, but the lines will be in the exact same spot they are now, just harder to see with a full screen of color....thanks
                    • jb.
                      • Nov 2016
                      • 33
                      • canada
                      #30
                      can you take some pictures of the tabs in question so we can see what were dealing with thanks
                      i will tonight,thanks
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4297
                        • Italy - Milan
                        #31
                        Ok the forum is big, one have to accept that some shit man come once every lot... with your poor brain you can only hope to open some tv and find the right day to change the right board, you're too stupidfor me and i never come more to this thread apart to celebrate your unsuccess (maybe it explodes to your face).
                        • jb.
                          • Nov 2016
                          • 33
                          • canada
                          #32
                          Ok the forum is big, one have to accept that some shit man come once every lot... with your poor brain you can only hope to open some tv and find the right day to change the right board, you're too stupidfor me and i never come to this thread apart to celebrate your insuccess.
                          vaffanculo
                          stop replying in this thread, you are useless
                          • jb.
                            • Nov 2016
                            • 33
                            • canada
                            #33
                            With the bezel off I can't change anything touching the tabs, only when the bezel is on when I give pressure near the tabs on both sides do the lines go away
                            • jb.
                              • Nov 2016
                              • 33
                              • canada
                              #34
                              *double posted
                              • heavymachines
                                • Mar 2011
                                • 1028
                                Weird indeed. So pushing on tabs at the glass edge does nothing, ok try this, you see the shiny mirror elongated ic's on those tabs? put something non conductive under those ic's like a rubber drawer bumper or wood even for this test and apply pressure carefully on the topside and see if it makes any difference sometimes those ic's will start to detach from the printed circuit. Pressure on ic like a sandwich.
                                • jb.
                                  • Nov 2016
                                  • 33
                                  • canada
                                  #36
                                  The shiny part not touching the glass loses the picture, with finger pressure no bezel, touching the glass brings back the picture, but doesn't affect the lines... I was hoping a simple shim work around, but it's puzzling for sure... On the inside of the bezel is what looks like metal tape all the way around, does that need to be in contact with tabs? Is it possible when pushing on bezel and the tape makes contact it fixes the issue?
                                  • heavymachines
                                    • Mar 2011
                                    • 1028
                                    ok don't think we're on same page, i'll see if i can find some examples online.
                                    • jb.
                                      • Nov 2016
                                      • 33
                                      • canada
                                      #38
                                      In the middle picture is that oval you see in the tab what you are referring to?
                                      • heavymachines
                                        • Mar 2011
                                        • 1028
                                        I can't find the exact video of the fix been few years buried on youtube somewhere however you can try to do this on every tab in the general area of the lines on screen and you can do this while tv is running. instructions on edited picture.
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          your problem is that you need to isolate which side is the issue. At the bottom of the set, the edge boards are "interconnected" with clampable flex cables. Look along each side of the bottom and disconnect the flex cable clamp / cable at that point. Does the remaining picture clear up? Repeat the "test" on the opposite bottom "half".... any difference? Go from there.
                                          PS. you still didn't follow my suggestion of putting up a known test pattern. :-(
                                          • x_orange90_x
                                            Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                            by x_orange90_x
                                            I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                            The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                            09-04-2023, 12:09 PM
                                          • arctor
                                            samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                            by arctor
                                            hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                            04-26-2025, 05:22 AM
                                          • x_orange90_x
                                            Samsung UN46C8000XFXZA Horizontal lines
                                            by x_orange90_x
                                            I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                                            I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                                            07-15-2023, 05:06 AM
                                          • blaster_
                                            Samsung UE49MU6105K - boot loop, horizontal lines
                                            by blaster_
                                            Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                            Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                            06-22-2022, 05:19 PM
                                          • porfyriadhs
                                            Tv Samsung UE50TU Horizontal lines
                                            by porfyriadhs
                                            Hello to everyone. I tried the tape method to by pass the on and off problem for the Samsung tv I mentioned. But unfortunately lines starts to appear. My question is if someone knows how to fix the lines problem...
                                            05-16-2024, 02:44 AM
