LG 79UB9800 heat problem
  • sushi1
    • Aug 2017
    • 32
    • Egypt
    My TV is generating excessive amount of heat from the back (especially around the main board and psu areas) even after operating for just a few minutes.
    I recently switched the main board due to video problems (maybe from the heat??) and I am really worried the new main board might eventually get the same problems.
    tried connecting it to a surge protector as well as directly to the wall, nothing helps.
    The TV supports 100-240v, and I run it on 220v.
    Shall I try connecting it to some sort of a stabilizer that outputs 110v?
    if that’s not the case, what could it be?
    I am sure this heat shouldn’t be normal.
    Model: LG 79UB9800
    thanks.
  • heavymachines
    • Mar 2011
    • 1028
    Re: LG 79UB9800 heat problem
    If the t.v is working good, i assume it is since you replaced main. You may need to modify it with fans. However is this tv running in air conditioned environment? Or is it room temps which i assume your area is rather warm.
    • sushi1
      • Aug 2017
      • 32
      • Egypt
      the tv is working great and I always make sure the room temp is good, plus there’s an AC right above the TV, but AC or not, it still gets considerably hot, so I don’t really think installing fans would help much.
      I was wondering if voltages can do that?
      and whether lowering the input voltage (within supported range) would help.
      • heavymachines
        • Mar 2011
        • 1028
        Is your a/c unit sharing same outlet or plug as A/C unit or same breaker at fusebox? if so then that explains it perfectly why your tv is running hot. Heavy draw on same circuit can cause everything plugged into it run hot.
        • sushi1
          • Aug 2017
          • 32
          • Egypt
          Just checked and nope they’re on seperate breakers and plugs.
          • heavymachines
            • Mar 2011
            • 1028
            Fan mod is only solution i can think of , others might chime in with other ideas.
            • vinceroger69
              • Mar 2012
              • 6714
              doing a fan mod does sound a good solution may have to cut back tv casing to allow good air flow and mount a fan or two over the main bga ics
              • sushi1
                • Aug 2017
                • 32
                • Egypt
                the worst TV i’ve ever dealt with, so frustrating not being able to figure it out... no more LG products for me.
                • Hamie
                  • Apr 2014
                  • 1383
                  LG really are making the worst mainboards ever.
                  I used to think they were bad but recently they have taken it to a whole new level of shit.
                  • sushi1
                    • Aug 2017
                    • 32
                    • Egypt
                    yeah don’t know whether it’s a mainboard fault, psu or poor ventilation and design, What I do know for sure is that LG is trash.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4458
                      • Italy - Milan
                      Suppling it with 110vac doesn't make any difference i think, you have to remove the back cover, and locate more precisely the heat, don't touch directly anything on the psu even with mains disconnected, use something flat and very hard to touch but not metal, it has to be thin, like a piece of glass, let it to warmup and check the part that is warming too much. A possible reason of it can be bad capacitors > high ripple, if you can replace them with good brands. Another possible reason is bad soldering on both mainb. / psu.
                      • sushi1
                        • Aug 2017
                        • 32
                        • Egypt
                        Not willing to take it off again, plus I am not much a tech. to check for bad caps and soldering stuff..
                        I have another thread and you suggested switching the mainboard, it worked and I thank you for that. In the mean time i’ll just hope it doesn’t go bad.
                        If you visited Egypt, come and take a look at it yourself (kidding)
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4458
                          • Italy - Milan
                          My suggestion is not strictly for your operation, you can let to make it by a tech. If any tech there is not able to change caps you're put wrong..
                          • sushi1
                            • Aug 2017
                            • 32
                            • Egypt
                            Will see what I can do, will definitely bring a tech soon.
                            Last question:
                            I can also feel static electricity running though the TV metal frame when I touch it even if it’s unplugged and nowhere near other devices, it’s on a wooden cabinet.
                            does this indicate voltage leak or is it normal?
                            • heavymachines
                              • Mar 2011
                              • 1028
                              Interesting. With it plugged in one would think it is lacking ground at the outlet can cause metal chassis to give you a shock. As with anything lacking ground plugged into outlet.
                              Or the air is really really dry can cause static.
                              Or you have something wrong in circuitry energizing the chassis. Current leakage to chassis can be a pin on backside touching metal or cap etc.
                              Dunno let other chime their opinions.
                              • sushi1
                                • Aug 2017
                                • 32
                                • Egypt
                                well it has been unplugged for nearly 30 mins now and can still feel the static, and nothing is touching it or plugged in it.
                                • heavymachines
                                  • Mar 2011
                                  • 1028
                                  Weird. Only thing i can think of is a capacitor storing energy and leaking to chassis. I am certain when a circuit is working correctly the built in resistors will drain them after it is unplugged unless there is something wrong. such as it touching chassis somewhere bypassing the resistor or something failed in circuit and energizing the chassis.
                                  I think i have read something similar somewhere on bad caps forums. Let the more experienced folks chime in on this one.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4458
                                    • Italy - Milan
                                    One thing is static electricity, one is leakage to ground currents, the first charges the metal chassis with a certain amount of charge that when you touch it you discharge it, the second is flowing continously and you feel it every touch, there can be a possible leakage on the big condensers i think, one more reason to change'em all even the 450v ones if needed. Not all PSU have discharge resistors so you can have charge after hours of wall plug unplugging.
                                    • sushi1
                                      • Aug 2017
                                      • 32
                                      • Egypt
                                      Should I be concerned? let the tech change the condenser? anyways I've attached the power supply pic. , if it doesn't have resistors or maybe anything odd that can be seen (I know that's unlikely).
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4458
                                        • Italy - Milan
                                        The 450v capacitors can't be because them are not connected to ground, the cap before the bridge are low capacity, them aren't, to feel a current with the hand the metal must be at high potential, i think more than 40v, so only the 100v cap for the backlight can be, but them can discharge to the leds probably, so i think the voltage come from antenna or if is not connected i don't know... need schematic..
                                        • Rofix
                                          Problem HP Main Board DAG3DCMBCC0 REV C
                                          by Rofix
                                          Hello everyone I wanted to kindly ask you for advice I have a problem with this HP Main Board DAG3DCMBCC0 REV C motherboard, the PC does not turn on, the power connector works, 19V arrives, on the first three mosfets there are 19V, the main voltages such as 3.3V and 5V are on the various coils, on the power button 3.3V arrives, I checked the power button and it works, but the PC does not turn on, moreover when I connect the power supply to charge the battery it does not charge, no LED lights up at the moment as the voltage is at 14.7V, the nominal voltage written on the battery is 15.4V, I also...
                                          12-19-2024, 02:10 PM
                                        • marcinq
                                          Samsung UE60KS7000 No Standby Light
                                          by marcinq
                                          I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                                          I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                                          05-26-2025, 11:36 AM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • bcstedt
                                          Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
                                          by bcstedt
                                          Just starting to crack into this one and wanted to get the ball rolling.
                                          At power on (plug in), power light on, relays click, repeat (sometimes)
                                          After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
                                          Removed Y-Main for inspection and testing
                                          This pic from:
                                          PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
                                          12-15-2023, 10:30 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
