LG 79UB9800 heat problem
  • petehall347
    • Jan 2015
    • 4450
    Re: LG 79UB9800 heat problem
    your electricity supply needs checking . i think live potential is on the ground wire ..had this happen here a while back .
    might not be that but best check it ..
    ignore all that if tv doesn't have an earth connection .
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4545
      • Italy - Milan
      But how a tv can store elec. charge on the chassis without any connection? To Sushi: is there any Radio / TV station / cellular antenna in your area?
      • sushi1
        • Aug 2017
        • 32
        • Egypt
        there’s a cellular antenna nearby, but I think the TV just needs better grounding, since there are no grounding plans in the building’s electricity layout.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          If Egypt has 440V service, (2 220V legs) then it will mean that a 220V line requires a neutral to avoid imbalance, which can cause a surge to come to the Tv,when on a leg that's not under heavy load, while the other leg is under heavy load by an appliance that's using a lot more watts than the Tv...
          (Such as the Tv on one leg, and a range or an air conditioner on the other leg!)
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • Rofix
            Problem HP Main Board DAG3DCMBCC0 REV C
            by Rofix
            Hello everyone I wanted to kindly ask you for advice I have a problem with this HP Main Board DAG3DCMBCC0 REV C motherboard, the PC does not turn on, the power connector works, 19V arrives, on the first three mosfets there are 19V, the main voltages such as 3.3V and 5V are on the various coils, on the power button 3.3V arrives, I checked the power button and it works, but the PC does not turn on, moreover when I connect the power supply to charge the battery it does not charge, no LED lights up at the moment as the voltage is at 14.7V, the nominal voltage written on the battery is 15.4V, I also...
            12-19-2024, 02:10 PM
          • marcinq
            Samsung UE60KS7000 No Standby Light
            by marcinq
            I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
            I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
            05-26-2025, 11:36 AM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
          • bcstedt
            Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
            by bcstedt
            Just starting to crack into this one and wanted to get the ball rolling.
            At power on (plug in), power light on, relays click, repeat (sometimes)
            After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
            Removed Y-Main for inspection and testing
            This pic from:
            PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
            12-15-2023, 10:30 AM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
