LG 42LH3000 Bad picture after T-con replacement
  • antas
    • Jul 2014
    • 148
    • Ireland
    Re: LG 42LH3000 Bad picture after T-con replacement
    IC100 can be transferred to the board with a bad picture or it not worth and I can get more damages?
    • tw2005
      • Oct 2011
      • 6458
      I'm sure you can whetehr that fixes it or not? If you want to return the board I would not , best thing I've purchased and very cheap, eeprom read / writer.
      perfect for this situation, copy contents of both and save, transfer the data from the donor. No physical removal of the chip.
      • antas
        • Jul 2014
        • 148
        • Ireland
        Thank you for your opinion. Unfortunately, this useful item is not in my toolbox... Can you give any link to buy this tool, please?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          http://www.ebay.co.uk/itm/24-25-seri...kAAOSwHoFXsz~r
          there are cheaper online heres ive included the software i use on mine
          • antas
            • Jul 2014
            • 148
            • Ireland
            ...there are cheaper online heres ive included the software i use on mine
            Thank you very much for your help. Could be this one the same? I chose this because of free shipping to the Ireland: http://www.ebay.ie/itm/CH341A-24-25-...MAAOSwGIBZsQNj
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #26
              yes that should work fine theres some good videos on you tube on how too use this programmer as you need too move one jumper on it usually
              https://www.youtube.com/watch?v=5NYe21nFSDI
              • antas
                • Jul 2014
                • 148
                • Ireland
                #27
                yes that should work fine...
                Thanks again. I'm gonna order this right now. Once I flash bios, I let you know the results here. See you soon...
                • antas
                  • Jul 2014
                  • 148
                  • Ireland
                  #28
                  Finally, the programmer has arrived. But have the problem with writing...
                  Any help, please?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #29
                    I have not had this error myself maybe stj can advise
                    • antas
                      • Jul 2014
                      • 148
                      • Ireland
                      #30
                      Maybe I do something wrong? The programmer can read, save, erase but when need to program, it shows this error
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #31
                        maybe the file your trying to write is too large?
                        • antas
                          • Jul 2014
                          • 148
                          • Ireland
                          #32
                          • antas
                            • Jul 2014
                            • 148
                            • Ireland
                            #33
                            Can be...
                            • antas
                              • Jul 2014
                              • 148
                              • Ireland
                              #34
                              Can be... I have downloaded the firmware for this tv from official LG site. But it is not a BIN file... Where can I get original file?
                              • antas
                                • Jul 2014
                                • 148
                                • Ireland
                                #35
                                I tried all possible changes on those chips (highlighted the picture) and have no changes. I tried replacing all them with places-no changes. Finally, I tried to reprogram them all but did find that they are not recognizing by the programmer at all. Can be that I am working in wrong place?
                                PS.: The programmer I have, works fine with computer bios chips (recognizing, read, program, verify)
                                Can anyone help me, please?
                                • Diah
                                  • Feb 2013
                                  • 6486
                                  reprogramming will never bring to you any result. while your version not matched LCD. you should find T-CON with 9YD01. no more or less.
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • Mgiffune
                                    by Mgiffune
                                    06-09-2024, 10:28 AM
                                  • kca
                                    by kca
                                    Hello all ~
                                    08-31-2025, 06:38 AM
                                  • boosti45
                                    Macbook pro logic board replacement parts quesion
                                    by boosti45
                                    i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                                    08-21-2024, 05:23 AM
                                  • advant
                                    by advant
                                    02-03-2020, 12:25 AM
