Sony Bravia LCD KDL-32L4010 four blink error code
  • dick_barton
    replied
    Re: Sony Bravia LCD KDL-32L4010 four blink error code
    Move your meter down to a lower resistance setting so that it reads ohms not Kohms
  • jackfish
    replied
    heres the transformer in question,,,,
  • jackfish
    replied
    put my meter to 60k..tested the bottom transformer..was 0.68..tested the top one..was 0.69......the small single one was 0.01...
  • dick_barton
    replied
    Yes well worth checking those out first and compare the resistance readings to each other. If memory serves me correctly there should no more than 3% difference in the readings.
  • vinceroger69
    replied
    did you check what budm suggested in post 20 transformers have been known to go faulty causing this type of issue
  • dick_barton
    replied
    If you solder a 10K resistor across C014 carefully without losing the capacitor, then do the lamps stay on.
    This was posted on another forum as a quick check to see if there was a CCFL tube problem, however I've never tried it.
    The idea behind it is that if there is a faulty lamp it forces the inverter to stay on.
    However it is only intended to be a quick test to establish if any of the tubes are faulty.
  • jackfish
    replied
    well im leaning towards a new inverter board..i did find one ..the exact same numbers on the board..but its from a kdl-32l5000 model.threre are green boards and blue boards..one was made in 2008..and one in 2009..mine is green...im guessing it should be ok....
  • dick_barton
    replied
    I believe it to be somewhere in the order of 1200V to 2500V AC so do not use your multimeter or you will be purchasing a new one.
  • jackfish
    replied
    what voltage am i suppose to be getting at the connection to the bulbs? im getting some weird readings..cranked it up to 600 on my multi meter.
  • jackfish
    replied
    they do come on for about 1 second...i took a fast pic..they all look the same brightness...ill look and see about the large ic...the boards on the service manual that was linked to me on this thread is completely different,.....
  • dick_barton
    replied
    Is the larger IC on the inverter board an OZ9972BN
  • dick_barton
    replied
    Originally posted by jackfish
    took it apart to see what was lighting it...seems to be ok...they all lit up...checked the caps on the board..there ok...
    I thought post #1 said they came on then went off. It may be worth your while checking that all the tubes are firmly held in their end connectors while you have it open. Also although it does not show in the photo, are any of the tubes dimmer than the others.
  • jackfish
    replied
  • jackfish
    replied
    these are the readings
    14..1.6
    13..1.4
    12..3.1
    11..1.8
    10..ground
    9..g
    8..g
    7..g
    6..g
    5..24.4
    4..24.4
    3..24.4
    2..24.4
    1..24.4
    im thinking board or bulb since its giving me 1.8 on the error out pin...
    replied
    SSI320_8C01 (Sony 1-857-518-11 (LJ97-02201A) Backlight Inverter)
    http://www.shopjimmy.com/sony-1-857-...-inverter.htm#
    Pictures provided by shopjimmy.
    I would check the resistance of the High Voltage windings of the Inveter transformers. Also check those two large lytics caps laying on its side.
  • dick_barton
    replied
    Post #3 says they come on and then go off so it's possibly a tube or inverter board fault.
    What voltages do you have on the 14 pin connector on the inverter board.
    What is the IC number in the middle of the board.
    replied
    BTW, are you 100% sure that you do not notice that the backlights come on for seconds when you first turn on the TV?
  • jackfish
    replied
    there it is...have to test it tommorow...
    replied
    There should be labels for the control signal pins on that inverter board connector: BL-ON (INV-ON), DIM, PWM-DIM.
    See what DC Volt you get on those pin, I assume you do get the 24VDC.
  • jackfish
    replied
    power board pic
  • cloo
    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
    by cloo
    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
    After doing a factory reset this problem was gone and the picture was back to...
    01-06-2025, 06:02 AM
  • reporter1979
    2 red blink code on old led tv Sony KDL-40W2000
    by reporter1979
    Hi all, the TV KDL-40W2000 was flashed by a lightning.
    Firstly I got the 3 red blink code.
    Following other threads I changed the power supply board and got always 3 blinks.
    So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
    The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
    What else can I do?...
    02-17-2023, 11:50 AM
    LCD LED TV Service Menu Codes
    ALL LCD LED TV SERVICE MENU CODES
    Service Menu Code with Board Name
    China Universal Board / Jumper Board Service Menu Code
    Changhong Ruba Service Menu Code
    Ecostar LED TV Service Menu Code
    Orient LED TV Service Menu Code
    Haier LED TV Service Menu Code
    TCL LED TV Service Menu Code
    Samsung LED TV Service Menu Code
    LG LED TV Service Menu Code
    Videocon LED TV Service Menu Code
    Supra LED TV Service Menu Code
    Toshiba LED TV Service Menu Code
    Symphony LED TV Service Menu Code
    Veste/ LED TV Service Menu Code...
    10-31-2024, 03:58 AM
  • Storyteller12
    Sony XBR-65X900E 4 Blink Code
    by Storyteller12
    I have this set. It turns on and is watchable for a few minutes but then shuts off and flashes 4 red lights.
    I don't work on Sony much but assumed it was backlights from what I read.
    Opened up the TV and tested all the backlights with led tester and the all work.
    I know sometimes that doesn't mean anything since it's not running at full current but I hate to spend $120 on backlights (shopjimmy) is the only one that even has them just to find out I missed something.
    So anyway to test these lights similar to the way we test...
    12-31-2022, 02:17 PM
  • PopsCaps
    Sony Bravia KDL-40V2500 that will not power on
    by PopsCaps
    I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
    I do not hear any sound and I cannot see any backlight.
    I have tried disconnecting every cable on each board one at a time to see if anything changes.
    The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
    My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
    03-25-2025, 11:23 AM
