Sony Bravia LCD KDL-32L4010 four blink error code
  • jackfish
    replied
    Re: Sony Bravia LCD KDL-32L4010 four blink error code
    hers the pics ...checked the fuse on the inverter board...its ok..
    replied
    It looks like Samsung LCD panel and Samsung Inverter board.
  • dick_barton
    replied
    What's the board number for the inverter.
  • jackfish
    replied
    just took it apart.....heres what im getting
    power on...3.15
    ac-off...3.29
    stb...3.30..
    unreg...16x2
    sground1..0
    sgro..0
    reg12..11.92x3
    on the plug to the backlight inverter
    pin one thru 4......24.3 to 24.4
    pin 6..7..8...0
  • cartgen
    replied
    https://servicemanuals.us/sony/tv/kd....html?start=10
    replied
    I guessed you did not download the service manual.
  • jackfish
    replied
    ok,,i guess that makes sense..lol..thats why i couldint find them....will be taking it apart tommorow..test out the boards....
    replied
    Per service manual this model does not use error code so that blinking light is not error code.
    We need pictures of the whole backside of the TV showing all the boards and pictures of each board.
  • dick_barton
    replied
    Generally if the backlights light up then they tend to be OK. However look carefully to see if there is a dark band where one may not be lighting up.
    Without any voltage readings it's hard to tell what the fault is. Do you have any photo's of your boards.
    You could try freezing the EEprom on the mainboard and then switch on in case it's a problem with that IC
  • jackfish
    replied
    could not find any info on error codes anywhere...if you ask sony all they tell you is to go to a service rep for repair...backights do light up..but dont know if one is blown..what does this tv use...ccl bulbs?
    replied
    Service manual:
  • jackfish
    replied
    anyone have info on the error codes....been looking around but cant find them for this tv...it turns on for a sec...black light comes on for a sec...turns off then four red flashes.....
    replied
    Its the Canadian version of the 4000.
  • jackfish
    started a topic Sony Bravia LCD KDL-32L4010 four blink error code
    buddy sent me a sony with he four blink error code...couldn't find any info on it...wondering if its like a 32l4000....well i crack it open an check it out...if anyone has any info ...thanks...
  • cloo
    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
    by cloo
    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
    After doing a factory reset this problem was gone and the picture was back to...
    01-06-2025, 06:02 AM
  • reporter1979
    2 red blink code on old led tv Sony KDL-40W2000
    by reporter1979
    Hi all, the TV KDL-40W2000 was flashed by a lightning.
    Firstly I got the 3 red blink code.
    Following other threads I changed the power supply board and got always 3 blinks.
    So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
    The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
    What else can I do?...
    02-17-2023, 11:50 AM
    LCD LED TV Service Menu Codes
    ALL LCD LED TV SERVICE MENU CODES
    Service Menu Code with Board Name
    China Universal Board / Jumper Board Service Menu Code
    Changhong Ruba Service Menu Code
    Ecostar LED TV Service Menu Code
    Orient LED TV Service Menu Code
    Haier LED TV Service Menu Code
    TCL LED TV Service Menu Code
    Samsung LED TV Service Menu Code
    LG LED TV Service Menu Code
    Videocon LED TV Service Menu Code
    Supra LED TV Service Menu Code
    Toshiba LED TV Service Menu Code
    Symphony LED TV Service Menu Code
    Veste/ LED TV Service Menu Code...
    10-31-2024, 03:58 AM
  • Storyteller12
    Sony XBR-65X900E 4 Blink Code
    by Storyteller12
    I have this set. It turns on and is watchable for a few minutes but then shuts off and flashes 4 red lights.
    I don't work on Sony much but assumed it was backlights from what I read.
    Opened up the TV and tested all the backlights with led tester and the all work.
    I know sometimes that doesn't mean anything since it's not running at full current but I hate to spend $120 on backlights (shopjimmy) is the only one that even has them just to find out I missed something.
    So anyway to test these lights similar to the way we test...
    12-31-2022, 02:17 PM
  • PopsCaps
    Sony Bravia KDL-40V2500 that will not power on
    by PopsCaps
    I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
    I do not hear any sound and I cannot see any backlight.
    I have tried disconnecting every cable on each board one at a time to see if anything changes.
    The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
    My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
    03-25-2025, 11:23 AM
