buddy sent me a sony with he four blink error code...couldn't find any info on it...wondering if its like a 32l4000....well i crack it open an check it out...if anyone has any info ...thanks...
Sony Bravia LCD KDL-32L4010 four blink error code
Re: Sony Bravia LCD KDL-32L4010 four blink error code
Its the Canadian version of the 4000.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Service manual:
could not find any info on error codes anywhere...if you ask sony all they tell you is to go to a service rep for repair...backights do light up..but dont know if one is blown..what does this tv use...ccl bulbs?Comment
Generally if the backlights light up then they tend to be OK. However look carefully to see if there is a dark band where one may not be lighting up.
Without any voltage readings it's hard to tell what the fault is. Do you have any photo's of your boards.
You could try freezing the EEprom on the mainboard and then switch on in case it's a problem with that ICWilling to help but I'm no expert.Comment
Per service manual this model does not use error code so that blinking light is not error code.
We need pictures of the whole backside of the TV showing all the boards and pictures of each board.Last edited by budm; 10-08-2017, 04:38 PM.Never stop learning
I guessed you did not download the service manual.Never stop learning
https://servicemanuals.us/sony/tv/kd....html?start=10Comment
What's the board number for the inverter.Willing to help but I'm no expert.Comment
It looks like Samsung LCD panel and Samsung Inverter board.Never stop learning
There should be labels for the control signal pins on that inverter board connector: BL-ON (INV-ON), DIM, PWM-DIM.
See what DC Volt you get on those pin, I assume you do get the 24VDC.Never stop learning
BTW, are you 100% sure that you do not notice that the backlights come on for seconds when you first turn on the TV?Never stop learning
SSI320_8C01 (Sony 1-857-518-11 (LJ97-02201A) Backlight Inverter)
http://www.shopjimmy.com/sony-1-857-...-inverter.htm#
Pictures provided by shopjimmy.
I would check the resistance of the High Voltage windings of the Inveter transformers. Also check those two large lytics caps laying on its side.Last edited by budm; 10-13-2017, 09:14 AM.Never stop learning
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
by reporter1979Hi all, the TV KDL-40W2000 was flashed by a lightning.
Firstly I got the 3 red blink code.
Following other threads I changed the power supply board and got always 3 blinks.
So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
What else can I do?... -
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
I have this set. It turns on and is watchable for a few minutes but then shuts off and flashes 4 red lights.
I don't work on Sony much but assumed it was backlights from what I read.
Opened up the TV and tested all the backlights with led tester and the all work.
I know sometimes that doesn't mean anything since it's not running at full current but I hate to spend $120 on backlights (shopjimmy) is the only one that even has them just to find out I missed something.
So anyway to test these lights similar to the way we test... -
by PopsCapsI have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
I do not hear any sound and I cannot see any backlight.
I have tried disconnecting every cable on each board one at a time to see if anything changes.
The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
My friend ordered another used power supply board but it is also doing the red indicator flash 3 times... - Loading...
