Vizio TV Legs Screw size
  • jstiene
    • Feb 2013
    • 148
    Hello. I have a few Vizio TV's with the Legs but no screws. I know they are M4 in most cases. I was wondering if anyone has a list of the various mm screw lengths for the newer model Vizio's. I wasn't sure if there was a specific pitch needed or just the mm length. Any help/suggestions would be appreciated.
    Thanks,
  • R_J
    • Jun 2012
    • 9611
    Re: Vizio TV Legs Screw size
    Check the tv service manuals (maybe owners manual), ie: Visio SV420XVT1A_LPL lists M4 X 26 (8 screws) The length will depend on the stands leg thickness
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • SS454
      vizio e650i-a2 backlight flashes then turns off
      by SS454
      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
      panel: au optronics T650HVN05.4
      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
      https://www.shopjimmy.com/vizio-56-0...-power-supply/
      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
      08-20-2020, 03:57 PM
    • mrtek
      Vizio M65-C1
      by mrtek
      Hi.
      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
      07-14-2025, 07:28 PM
