Vizio will not turn on
  • fmlu
    • Nov 2014
    • usa
    I have a Vizio M502i B1 and yesterday I found it turned off and it would not turn on. Originally as I tried the white light on the side of the tv would come on Some times the screen showed the vizio sign in the middle of the screen but this then disappeared and tv did not come on. I then tried power cycling the tv a couple of times, after power cycling not even the white light on the side came on. In fact after the power cycling nothing at all happens when I try to turn the tv on.
    Unplugged tv and left it unplugged overnight; this morning I put the plug back in and the TV powered on without any problem. It has now been running for over five hours without any problems. Any ideas as to what might be the problem. Thanks in advance
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio will not turn on
    Need good clear straight on pictures of back of tv with cover off and each board.
    • fmlu
      • Nov 2014
      • usa
      Roundbox has already posted pictures for this model M502i-b1. Looking for information as to what might be the cause of this problem.
        Since it is working right now, then you should record the DC Voltage reading of the power supply connector pins that go to the main board, then take the reading when the TV stops working.
        • Mulp
          VIZIO M65-C1 Does Not Turn On
          by Mulp
          Hi All,
          I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
          When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
          I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
          01-13-2024, 09:57 PM
        • high-tech
          Samsung UN55F7050AFXZA ver. TD01 power cycling
          by high-tech
          Hello everybody, I could use some help on this one... It's got me guessing...
          I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
          (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
          (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
          (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
          (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
          9. ground (PWM2) 10. 0.9 volts cycling...
          09-15-2020, 03:39 PM
        • pajdek
          Lenovo Y700-17ISK turn on and off
          by pajdek
          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
          09-20-2023, 02:49 AM
        • RdeveLabs
          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
          by RdeveLabs
          To all the members here...
          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
          05-05-2025, 04:59 AM
        • Journey11
          Samsung TV won't turn on ... keeps cycling the power relay on & off
          by Journey11
          Hi All,
          First time posting here ... my name is Kevin but my friends call me Journey.
          I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
          After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
          It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
          07-04-2024, 02:44 PM
