LG 55LE5400 Nice TV BackLights Only Half Picture...
  • Michale32086
    • Nov 2011
    • 1453
    Got a nice LG in...
    With everything hooked up, I get backlights but no image..
    That tells me that the Power PCB and the middle (Inverter??) board are probably doing their jobs...
    There is no TCON board. The Main board LVDS cables (pair) go directly into the display panel's "buffers"??...
    Now, when I unhook the right LVDS cable, I do get the normal LG image on half the screen.. It appears to be faint, but I am thinking that is likely just due to a menu setting as opposed to an indicative problem..
    A replacement Main Board is spendy, but worth it if it fixes the TV.. But if it's the panel buffer that's bad, then I don't want to waste the $$$ on a replacement Main board..
  • vinceroger69
    • Mar 2012
    • 6714
    Re: LG 55LE5400 Nice TV BackLights Only Half Picture...
    possible shorted smd capacitor on the lcd panel pcb on the side that shows no picture there has been a couple of threads with a smd cap causing issue like this
    • Michale32086
      • Nov 2011
      • 1453
      I was afraid of that... I never have any good luck with fiddling with the panel PCBs...
      Thanx for the reply..
      • diif
        • Feb 2014
        • 6978
        • England
        You have nothing to loose apart from a little time.
        Check the caps for shorts in diode mode. You might get lucky and it just be a cap or it could be a shorted COF as was my case.
        • zomi
          • Nov 2011
          • 512
          check the caps
          if u find more than one shorted remove one by one and check once they are removed
          normally u just have one that is shorted and the rest on the same line are fine.
          heat ethier side one cap bath and forth with hot iron and then nudge off with tweezers
          • Michale32086
            • Nov 2011
            • 1453
            Yea, time is the big factor around here.. The LVDS cables look pretty scraggley on the ends. I am hoping that's the problem, but have swapped out diff ones and no help.
            So I have a feeling it is the panel boards..
            Putting it aside til I have a full day..
            Thanx
            • Michale32086
              • Nov 2011
              • 1453
              Originally posted by zomi
              check the caps
              Thanx.. I'll give that a try
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • gavric
                Vizio M70-C3 Half picture is bad, main board on its last leg?
                by gavric
                Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                When tv powers on vizio V logo shows nice on whole screen. picture 1
                When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                When i click video to start playing picture goes black(like when you change...
                09-02-2021, 08:55 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
