Samsung UE32EH4003 no picture
  • Norman1
    • Jun 2017
    • 77
    • Uk
    Hi guys, got a faint picture on this Samsung, got 180v on pin 1 of the backlight connector and nothing on the other 4. Should there be?
  • Norman1
    • Jun 2017
    • 77
    • Uk
    Re: Samsung UE32EH4003 no picture
    Power supply pic
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      1. Disconnect the jack going to the Main Bd.
      2. Turn ON tv.
      3. Do the Backlights come ON now?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Hello Norman, Out of interest, were you successful with any of your other repairs.
        Does the board say led voltage 112V @ 260mA which would suggest that 180V is the open circuit voltage and the led strip is probably open circuit. Either a bad led(s) or bad led strip connection.
        • Norman1
          • Jun 2017
          • 77
          • Uk
          Hi Andrew, without the main board attached there's no picture at all, not even a dark one. Hi Dick, on the pcb it says 65v 450ma. So if the voltage is high is that suggesting the led's are open circuit not bringing the voltage down?
          • Norman1
            • Jun 2017
            • 77
            • Uk
            Iv repaired a fair few of them except the ones with backlight problems, I havnt attempted one yet, but I have a few here now so I will crack one open as soon as I get time and see how I get on
            • CDRW
              • Aug 2017
              • 5
              • Ukraine
              you need such a device to diagnose the backlight. Without disassembly of the display
              https://ru.aliexpress.com/item/NO-di...81e3364a&tpp=1
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                I probably didn't say it right....You WILL NOT get a picture with the cable from PSU to Main Bd disconnected....I wanted you to look for the backlights through the holes at the back of the panel.......You do however have bad backlights though from what I read......Can you strip the panel down to reveal the LED backlight strips??
                • Norman1
                  • Jun 2017
                  • 77
                  • Uk
                  I have that device in my armoury there is no sign of any light from the led's at the rear. When replacing led's individually can you use led's from a different make/model/size TV? Or are they different voltages ect?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    LEDs can be a different size, colour and mounting. There are a couple of voltages too.
                    • Norman1
                      • Jun 2017
                      • 77
                      • Uk
                      So is there a way of telling which ones out of a scrap tv will go in another tv? Are the volts marked on the pcb strip or anything?
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        You could spend time cross referencing numbers on sites like ebay and shopjimmy although some look the same from the top but not the bottom.
                        I'd just remove the faulty LED, check my stash for the same LED then look for a new one online if I didn't have one in stock.
                        There are people selling replacement strips just get an identical one.
                        • Norman1
                          • Jun 2017
                          • 77
                          • Uk
                          I have a few TVs to strip down when I get a minute, il have another look on eBay as well,the last time I looked on there for led's they were prices were way to high,
                            09-07-2024, 05:50 AM
                          • TR103
                            by TR103
                            - it keeps rebooting
                            01-22-2025, 04:12 PM
                          • JJAAMM
                            by JJAAMM
                            Problem
                            07-06-2023, 06:01 AM
                          • Mgiffune
                            by Mgiffune
                            06-09-2024, 10:28 AM
                          • Dodgethis
                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                            by Dodgethis
                            Hello all,
                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                            09-11-2024, 07:39 AM
