LG 79UB980T Video problem
  • sushi1
    • Aug 2017
    • 32
    • Egypt
    hello,
    i've been having a problem with my LG 79UB980T, there's no picture visible in all the inputs (only vertical lines with a usually pink background flickering), tried satellite receiver, Xbox One, movie from a USB Harddrive & PS4. even the built-in youtube app and netflix show no videos.
    however i can see the menus with flawless full colors and listen to sound perfectly, it only appears when anything is played.
    *I use only high quality hdmi 2.0 cables. (if it matters)
    *I once used cheap HDMI splitter
    I thought it might be a T-Con issue at first but the TV worked perfectly for two days after changing it's location (weird i know), then the issue came back.
    So I opened the TV, jiggled the wires and connections a little bit, nothing happened, the boards look perfectly clean and no signs of burnt up capacitors or stuff like that.
    What could it be?
    Pic attached.
    thanks
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 79UB980T Video problem
    Well I am tempted to say put it back where it worked before....But I think this is aT_CON issue.
    • sushi1
      • Aug 2017
      • 32
      • Egypt
      It is in the same place ever since, I just covered the screen with a bedsheet.. My question is.. how do I know for sure it's a T-Con? does the T-Con distinguish between the menu screens and whenever a video content is played? because as far as I know, if it was T-Con related, these vertical lines would be all over the menus as well? Correct me if I'm wrong
      • sushi1
        • Aug 2017
        • 32
        • Egypt
        Another question, assuming it's a faulty T-Con, how can it possibly get fixed by itself for a couple of days?
        • diif
          • Feb 2014
          • 6978
          • England
          I'm guessing there are two processors on the mainboard, one does the menus and there is another to do image processing, this one had BGA issues.
          It sometimes only takes a light press on the processor to make/break connections (bring the picture back) so it's possible moving it caused it to temporarily work.
          • sushi1
            • Aug 2017
            • 32
            • Egypt
            Exactly what I had in mind, So that's a Main board issue, not T-Con?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4467
              • Italy - Milan
              Excuse me you have a 79 inches so you probably rich and you can't carry it to a service center? Or you want a diagnosis just to be sure? Attempting a self repair on beast like this is risky... For me is impossible tcon, is surely Mainboard, what exactly i don't know, 'cause i don't know the model... Since the location change story i agree with bad bga soldering, the problem seem to be video decoding, so maybe a certain RAM chip bad soldered.
              • sushi1
                • Aug 2017
                • 32
                • Egypt
                I am not attempting to repair it myself, I just want diagnosis because I am in a country where technicians cannot be trusted.
                • sushi1
                  • Aug 2017
                  • 32
                  • Egypt
                  I found several main boards online that exactly match the one that needs replacement, same board model no. but not taken from the same TV size as mine. they're either taken from 65" or 84" models while mine is 79"
                  (does the TV size matter?)
                  I need someone to point me in the right direction for selecting a compatible board.
                  mine is EAX65608604(1.1)
                  took a couple of pics of the board
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4467
                    • Italy - Milan
                    The size matters.. you can become to a video not comprensible due to different incompatible brand of lcd panel, i think is possible by a technician but it must do some steps more (copy of eeproms, firmware flash)...
                    • sushi1
                      • Aug 2017
                      • 32
                      • Egypt
                      It worked again after leaving it turned off for nearly a week.. this time without changing places, weird right?
                      Im currently waiting for a new main board to be delivered, but i'm lost here.
                      Why does it work after being turned off for a few days? bad soldering? bad PSU? corrupted software?
                      • koka0011
                        • Apr 2013
                        • 30
                        • Sri Lanka
                        check gamma voltages
                        • sushi1
                          • Aug 2017
                          • 32
                          • Egypt
                          I doubt that's the culprit since menus are clearly visible, but will look it up just in case.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4467
                            • Italy - Milan
                            Gamma voltages?? Why? it's unuseful for me... bad soldering of the cpu is the main suspect, you can provide your mainboard to a reballing service or buy a new mainboard.
                            But you've bought a new MB so if doesn't work the minimum you can do is to let someone copy the content of the setting eeprom of the old MB to the new MB (or a chip swap) and after try to upgrade with a firmware for the model that the new MB come from. BYE.
                            • sushi1
                              • Aug 2017
                              • 32
                              • Egypt
                              * the TV works fine after leaving it turned off for a couple of days.
                              * it will continue to work flawlessly ONLY if I left it switched ON (can leave it 10 hrs no problem)
                              * if I switched it OFF even for 1 sec. and turn it back ON the issue comes back and I have to wait another couple days for it to work again.
                              I am still waiting for a new mainboard to arrive but in the mean time,
                              I am really intrigued what would cause this mind bending issue.
                              *I know Bad BGA soldering is the main suspect here,
                              but I have this feeling, it can be caused by another really small / dumb issue.
                              can it be something else?
                              *Sorry for asking many questions, I know I’m a bit annoying, but the TV is driving me crazy.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4467
                                • Italy - Milan
                                Another source of possible problems on the mainboards are power mosfets or linear voltage regulators but its difficult to put them in relationship to the behaviour of the defect. It quite strange, it seems something involved only in the startup that works better warm, i dont know which one. Maybe something that holds settings information like the eeprom or the startup software like the flash spi if present..
                                • sushi1
                                  • Aug 2017
                                  • 32
                                  • Egypt
                                  How about an EEPROM reset?
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4467
                                    • Italy - Milan
                                    No good idea, unuseful for me..
                                    • sushi1
                                      • Aug 2017
                                      • 32
                                      • Egypt
                                      okay, popped in a new main board and the TV worked fine..
                                      thanks for your help
                                      What I am really concerned about is if the new main board will adapt well to 220v power instead of 110v? since I bought it from the US while I’m in a different region.
                                      It’s the exact same board no. but was taken from a TV that was working under 110v
                                      thanks
                                      • alro7779
                                        Samsung UN55MU6103F video problem; has colored stripes on the display
                                        by alro7779
                                        Hello, everyone!
                                        A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                        09-27-2025, 11:29 PM
                                      • Spikeman
                                        Help on Video Problem on Dell Inspiron 7459
                                        by Spikeman
                                        Hi, I'll tell you the story of this PC.
                                        The PC was repaired because it had a shorted power supply. What happened was that the plastic covering the buffer battery positioned by the manufacturer on the capacitor melted, thus generating a short.
                                        After the repair, the PC worked, I installed Windows 11 and I may have had some problems with the video drivers, but after a bit of tinkering I think I solved them.
                                        However, the PC later presented the problem in the video shared very frequently.
                                        The problem also occurs at startup, in the bios and when using it as a monitor thanks...
                                        02-27-2024, 10:17 AM
                                      • Gibon378
                                        Problem with stopping audio and video for no reason
                                        by Gibon378
                                        PC Specs:
                                        • CPU: Ryzen 5 1600
                                        • GPU: GTX 1080 Palit JetStream
                                        • MOBO: ASRock ab350 PRO4
                                        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                        • PSU: XFX 650W (don't remember what model)
                                        • OS SSD: ADATA SP920
                                        • OS: Windows 10 21H2
                                        Problem description:
                                        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                        11-19-2022, 09:41 AM
                                      • zimeyh
                                        Problem video A1502
                                        by zimeyh
                                        Hi guys! I have a problem with macbook pro A1502. This display have a apple video, when launch desktop, this display is off. A connect thunderbolt a monitor, have video and laptop and monitor. Disconnect thunder video power off. Whats problem? 🤦🏻*♂️ thankss
                                        11-15-2023, 03:19 AM
                                      • hugocarmo
                                        Grundig GV-250 Repair problem. (Video inside post)
                                        by hugocarmo
                                        Hi everyone.
                                        I have the following problem.
                                        I have a Grundig GV-250 VCR which has not been used for over 10 years. When I turned it on, the fuse of the PSU burned out, after being replaced it burned again, I ended up verifying that I had the bridge rectifier and the mosfet in short, I ended up replacing it, and I replaced all the electrolytics of the PSU. However, it started to behave strangely, as I will show you in the video that I will attach as a link.
                                        In short, I ended up replacing all the ICs on the power supply CNY17G, TDA4605, TL431, TDA8137, TL082CP, AN3824K, L2720,...
                                        01-19-2023, 06:46 AM
