LG 55LD520 HDMI Problem (No signal)
  • curt2199
    • Oct 2013
    • 54
    I'm using my Fire TV and on the side HDMI (3) I get the center amazon text when it first boots and then nothing but a black screen. On the 2 back HDMI I get "No Signal". The TV recognizes that something is plugged into the HDMI port because I can select the respective port.
    I found some similar LG issues that were solved by heating or baking the main board to reflow solder and I'd fixed a couple video cards this way in the past so I gave it a shot. I attempted the heat gun first followed by baking at 385 for 10 minute. Neither resolved the problem. Is it possible there is just a chip that needs replaced? Replacement boards are running around $125 on eBay and that's just not kosher to me.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8158
    Re: LG 55LD520 HDMI Problem (No signal)
    Chances are slim. The HDMI inputs are going straight to the main IC.
    • diif
      • Feb 2014
      • 6978
      • England
      385 isn't hot enough to reflow the solder.
      I've fixed a couple of LG mainboards giving them a reflow but using an IR rework station.
      • Nick's Tvs
        • Jan 2014
        • 621
        I really don't suggest baking them, but instead actually performing a rework/reball, or replacing the chip itself., otherwise you are only buying yourself a few extra weeks/months to about a year before the board fails again It is possible that the chip could have failed internally in a way that even a reball won't do the trick.
        What is the part number of your main board?
        Also melting point of solder is about 180 celsius but varies a few degrees dependent on the type. This means if you put it in an oven at 356 farenheit or higher, it should do the trick for a reflow. This means 385 is more than enough and you wouldn't want to go any higher since this is an oven heating up the entire board. If you did go higher you would risk all components on the bottom of the board just falling off. diif is using a ir rework station, you can focus the heat onto one specific spot instead of the entire area of the board, that is why he is able to get away with a bit higher heat.
        Just be very careful doing these things, I highly suggest practicing on bad boards as most often if it does not work, you are about to break your board in ways you won't know how to fix.
        • diif
          • Feb 2014
          • 6978
          • England
          Leaded solder is about 183c but lead free that's on the chip and board originally is about 220c.
          • curt2199
            • Oct 2013
            • 54
            The board is EBR66473904. I can't really tell what chip is handling the hdmi inputs unless its the big XD engine chip in the center of the board with the heatsink.
            • dskall
              • Oct 2016
              • 2905
              • usa
              385f =196c
              • diif
                • Feb 2014
                • 6978
                • England
                Yes, the big XD engine is the chip I reflowed after removing the heatsink to about 230c.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4330
                  • Italy - Milan
                  To Curt: "I get the center amazon text" what is?? A tablet pc??
                  Why you don't cook some cookies or a pie instead of PCs and TVs? :-)
                  If you cook also food in that oven you don't have fear that you eat dangerous plastic substances?? Take at least an heat gun..
                  HDMIs are all connected to a smal 8pin eeprom, this can be bad, you can change it and after you can go to a friend with a similar TV (i never tried) with free Moninfo software, you download EDID data from it then save it an load to your tv, instead of this usually LG pubblish EDID data on their Service manuals, BYE.
                  • natiz
                    Samsung UE65MU7003U / BN41-02568B - HDMI No Signal
                    by natiz
                    Following a power surge, the HDMI ports on a UE65MU7003U no longer work, no matter the port or the source - it shows No Signal.
                    The other functions work well (eg Netflix app, etc.), its just the HDMI ports.
                    Is the BN41-02568B board salvageable? Any leads before I open the heatsink cover? board replacement?...
                    09-12-2024, 03:52 AM
                  • Comp_Pro
                    PS5 HDMI not outputting CK/DA Signal
                    by Comp_Pro
                    Hello all,
                    I am trying to repair this PS5 which came in with a shorted HDMI encoder chip. This issue was not allowing the PS5 to boot and would only beep upon pressing the power button. This is the first time I've had this issue despite replacing many many HDMI ports. After installing the new chip as well as a new HDMI port the console now powers on and appears to be booting all the way but there is no video output. Looking at my HDMI tester all signals are present except for DCC Clock and DCC Data aka CK/DA on my particular tester. These two have direct connections to the encoder...
                    10-09-2023, 01:38 PM
                  • jimbofz
                    harwa 42 lcd tv no hdmi signal output
                    by jimbofz
                    theres no precise model number on the rear cover boards labelled as below
                    Hi just been given this lcd tv,
                    ive not come across this make before
                    there is no o/p from hdmi .its fine with scart .
                    good pic for its age
                    the main board is 782 L42W17-690B
                    cant find much info on google
                    to enter service menu .bring up a/v menu ,then 2580
                    but cant move to next page ,for options
                    (i was hoping ther may be an option to switch on/off hdmi/dvi)
                    the reason for this , is when hdmi is selected it says: no dvi signal
                    not: no hdmi...
                    01-06-2022, 05:57 AM
                  • FrancescoV
                    Onkyo HT-R390 no sound output, video output ok
                    by FrancescoV
                    Good morning everyone,
                    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                    The firmware reported is the following:
                    M:1.00/11107BLP
                    D:?.??/????????
                    O:1.00/11107AL
                    The DSP firmware given the question marks seems corrupt.
                    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                    05-11-2025, 02:59 AM
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
