I have fixed 2 tvs with bad leds with leds I had from junk sets. I have an lg 55lb5550 that's needs leds, my backlight tester shows the good onestuff pull 5.4 volts. How do I find out the number of these leds and where is a good place to buy them. I've have tried every number I have on the strips, panel number, I'm not sure how to find out what number they are . Helpppp
Leds
Tags: None
Re: Leds
I would measure them and look on aliexpress
Also look here: http://alpengeist-tvrepair.blogspot....ces-tools.htmlLast edited by dskall; 08-23-2017, 07:12 PM.I assume no responsibility for any stupid suggestions I might post.Comment
Re: Leds
Seems like there should be a set of numbers in which you can tell which leds are used in a tv. Don't have anyway to measure in mmComment
Re: Leds
The best you can find is strip numbers because no manufacture sells just the led. If you have ruler or anything you can cross to mm. They look to be 2.8 X2.8mm. But I have no real referenceI assume no responsibility for any stupid suggestions I might post.Comment
Re: Leds
You need to remove the LED to check the foot print of the LED and measure the dimension of the LED. You also need to verify the forward Voltage of the LED to find out if it is single (3V forward Voltage) or Dual (6V forward Voltage) LEDs.
Notes: one string of LED has Vf of 138.6V, the other string has Vf of 207.9V.Attached FilesLast edited by budm; 08-25-2017, 09:41 AM.Never stop learning
by the_remHello guys,
I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow... -
by sikocanI believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
SN: PF3G1REP
MODEL: 20KW-00J1AU
PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
Channel: BIOS Requests ONLY!
by xxxchudyxxxHi,
i have a corrupted BIOS file from a laptop, but i need to recover the serial number and DMI info (like product name, UUID, etc.). I also have a good BIOS dump from the same model.
Is there a simple way to copy the DMI data from the bad file to the good one?
HP 650 G3
Thanks!...-
by GentianI have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
by ameesh.pdell inspiron 14plus 7420 ic burned anyone help me to find number? i will attach photos. Any one have schematic....
- Loading...
